audio gurus - need input on system design
I have an early car in which the radio has been replaced with a CHT gauge and voltmeter. And while I like the look and the piece of mind the added instrumentation brings... I'm starting to miss the tunes. So I've started to plan a fairly modest sound system that will use a portable mp3 player as its only source. But frankly, I have no clue on what is good or bad other than what could be gathered from the archives, so I need some help.
BTW, I like my music clean and tight, but not too bright (I'm 45) and listen to everything from Rage Against the Machine to Roland Kirk (primarily the latter, though)... So what do you guys think? Source: Ipod, 30G - colour: black Direct to Amp Interface - Hifonics MM-1 Car Audio iPod/MP3 Interface: http://www.sonicelectronix.com/item_7923_Hifonics+MM-1+Car+Audio+iPod-MP3+Interface.html Amps - 2x MB Quart PAB 2100 Premium 2 Channel: http://www.sonicelectronix.com/item_9483_MB+Quart+PAB+2100.html Speakers (front doors) - MB Quart PCE 216 Premium Series 6-1/2": http://www.sonicelectronix.com/item_699_MB+Quart+PCE+216.html Sub (smugglers box) - MB Quart DWG 254 10" Discus Series Subwoofer: http://www.sonicelectronix.com/item_8320_MB+Quart+DWG+254.html or http://www.sonicelectronix.com/item_9660_MB+Quart+RWE+204.html
'70 911S 1002938 '70 Ducati Mark 3D 350 Last edited by derek murray; 07-20-2007 at 08:07 PM.. |
weekend bump... before I lay down the credit card
'70 911S 1002938 '70 Ducati Mark 3D 350 |
Fahren mit dem Wind.
Derek, I see you have a 70S too! Just curious, how does a sub in the smuggler's box work?
Take a look at the post I just made on retrofitting the Blaupunkt shelf speakers in my S: Blaupunkt shelf speaker rebuild I didn't feel good about cutting holes in my door panels! Cheers, Michael
Keeper of the 1983 911SC Cabriolet Registry (http://911sccabrioletregist.freeforums.net) Caregiver to: 1983 911 SC Cabriolet - Fahern mit dem Wind. (Moss Green Metallic over Champagne and Brown Leather) |
AutoBahned
MB Quarts are good speakers.
You'll get more responses if you list the items, rather than force people to follow URL to find out what you are talking about.... |
one of gods prototypes
sounds like your on the path i've been on for a bit......sirius stiletto as my only source
![]() here is my thread.....amp rack is finally done ![]() 911 audio build.... the quart 6.5's are nice, they like power though, that "mb quart" amp isn't "that" powerful, look into the JL 300/2 if the budget permits. the hifonics source adapter will work, you'll probably need to add an rca ground isolator as they can be noisy.....a PAC rca filter works every time.
Brought to you by Carl's Jr. |
911 audio the way it was meant That is a great retrofit, btw... nice work!
'70 911S 1002938 '70 Ducati Mark 3D 350 Last edited by derek murray; 07-20-2007 at 08:30 PM.. |
Banned
I put an amp under the passenger seat, a sub under the drivers seat (tried the sub in the trunk and it didn't work well), seperates in the door and shallow speakers just for fill in the rear. It sounds great.
Seperates in the front are very important to get the tweeter up high where it is not muddled. Here are a couple of photos so you can see. I get pretty anal about things sometimes and I think this is just about as good as I could get it. Good luck
i am currently working on making the single 10" fire directly into the cabin from the base of the smugglers box, this will entail some cutting to make room for the magnet, the face of the enclosure will bolt where the pass foot board is and will become part of the chamber. when the chamber of the smugglers box is made you end up with a right around 2/3 cu foot, so sub selection is important for it to work with the airspace you end up with......build the "box" first then measure the airspace. for absolute accuracy place a trash bag in the "box" (triple bag it) and fill with water, that ammount of water can be converted to volume by some math, i cheat and use a 12"x12"x36" box on end and pour in the water, drop in my strait edge and there's my volume.....always better to be a little big for the woofer, as making the internal volume of the box smaller is as easy as adding some wood....once you have your numbers. sorry for the ramble.....i spent the day installing a big ass radar system in a gallardo and am drinking some XX
Banned
I tried a bazooka bass tube strapped to the strut tower brace. Vibrated the hell out of the car but didn't provide the bass properly.
Then I ported about six 3'' holes into the cab above the feet to allow the sound into the cab. Still didn't work. The sub under the seat is by far the best way to get bass in the cab, I think kenwood makes it. Look it up, it's made for under seat applications. |
aimed mid between driver & passenger heads.
wedge is for 6.5
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Designer King
Can't comment on audio systems, but I once saw Roland Kirk play a show @ the Fillmore in NYC about 1970 with Santana and the Tower of Power. It was amazing. He played the sax, flute and folding wooden chair all @ once!
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
