KatoKato's Avatar
Carrera A/C Fuse / Relay Questions (One more time...)
I removed the A/C last year and am wondering about the fuse & relay on the fuse panel.
The schematic states that fuse number 2 is for booster fan, A/C, & electric seats.
Since both seat switches don't work can I just remove this fuse?
I'm asking because of the copper conductors linking fuses 2, 3 & 4.
Will removal of fuse two have an adverse effect on 3 & 4 as a result?
Also - Would removal of the A/C relay on the fuse panel have any effect on fuses 3 & 4 as well?
Your thoughts would be appreciated.
Thanks,
Kato
Old 07-24-2007, 12:58 PM
Used Up User
imcarthur's Avatar
Kato
The links are on the hot side vs the lower fused side, so they will have no impact on fuse removal. Relay #6 is for the AC condenser blow & looks safe to remove too.
Ian
'87 Carrera Cab
Old 07-24-2007, 04:05 PM
KatoKato's Avatar
Originally Posted by imcarthur View Post
Kato
Ian
Thanks Ian. Just wanted to be sure.
So why are those links placed like that?
Do they supply power in parallel across fuses 2, 3, &4?
Old 07-25-2007, 04:22 AM
Used Up User
imcarthur's Avatar
Yes, they do.
Reason: Teutonic efficiency. Simpler than more wires to strip & route.
Ian
'87 Carrera Cab
Old 07-25-2007, 06:14 AM
KatoKato's Avatar
Ian
Re: Fuse#2
Do you know what 'booster fan' the schematic is referring to? (I am assuming that it is A/C related)
There is also a relay at position 'F' (or close to that position) for this booster fan as well.
Kato
Old 08-13-2007, 07:09 PM
burgermeister's Avatar
All 3 fuses are constant power from battery, big supply wire, not switched by ignition, and jumpers are on the non-fused side. So you could take it out...
But why not just leave the fuse in there? It might make a nice spare to get you home someday.... ditto for the AC relay...
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 08-14-2007, 05:11 AM
KatoKato's Avatar
True enough .... I am just trying to reduce the chance of a short with these dangling plugs at various locations in the car. I suppose that the chances of that occuring are unlikely.
Perhaps I'll just leave them in...
Besides ... I just checked Bentley and it lists that relay for the power windows. I'll have to check it out..
Old 08-14-2007, 05:25 AM
