ATP ATP is offline
ATP's Avatar
help, power but no start?
I pulled my 79 sc out of the garage. Put my key in turned, nothing turned again nothing then the third time it started no problem. I figured that the battery was low, went for a five mile drive, pulled into the wash bay at the shop. After sitting for a few hours I tried to go home, I turn the key and nothing happens.It does not try to crank or evn click. I have power to everything but doesn't see to have any to the starter. What is my firt move?
AP
79 Scout II
02 explorer
01 frontier sc
79 sc coupe
Old 07-28-2007, 05:39 AM
Carrera Cab Connoisseur
nyne11's Avatar
Check the condition of all your earth straps would be a good start.
Dave
1986 Carrera Wide Body Cabriolet
1993 Nissan 300ZX Twin Turbo (620rwhp)
2003 BMW 330Ci MSport Individual
1973 Mercedes 350 Custom Convertible
Old 07-28-2007, 06:31 AM
ATP ATP is offline
ATP's Avatar
What is a earth strap?
AP
79 Scout II
02 explorer
01 frontier sc
79 sc coupe
Old 07-28-2007, 06:50 AM
nyne11's Avatar
Ground cable, Earth strap...same thing. There will be a number of them....not sure on a 79 but there should be one from the starter motor to the chassis and of course negative side of battery to chasis. But there are others. Sounds to be like a bad earth connection.
Dave
Old 07-28-2007, 07:00 AM
Designer King
Paulporsche's Avatar
Try recharging the battery. A 5 mi run won't bring the charge up very much.
It could also be your starter/solenoid.
Or your ignition switch.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 07-28-2007, 09:44 AM
ATP ATP is offline
ATP's Avatar
Alright I think that I have found the problem, solenoid on the started is bad. The only way I can start it is by jumping across the solenoid to the starter. Can you buy just the solenoid or will I have to replace the whole starter assembly? If so where can I find one? Thanks Adam
AP
79 Scout II
02 explorer
01 frontier sc
79 sc coupe
Old 07-31-2007, 07:51 AM
ATP ATP is offline
ATP's Avatar
Although now that I think about it I guess it could also be the electronic part of the ignition switch as well. Still wonder about a solenoid replacement.
AP
79 Scout II
02 explorer
01 frontier sc
79 sc coupe
Old 07-31-2007, 09:04 AM
That's what I did and I got my solenoid at my local independent Porsche repair shop.
I think it cost about $75.00.
Joe
Old 07-31-2007, 09:39 AM
