rde rde is offline
Chip Problem?
I installed a Steve Wong chip in my 88 cab a few weeks ago. Great boost in performance! However, lately the car will lug (i.e. buck) at low RPM's and will also occasionally smoke at start-up and smoke when engine is cold and leaving from a dead stop.
Engine has 70K miles and I didn't have these issues with the stock chip. Any ideas?
Old 08-02-2007, 02:35 PM
Did you change the oil or top it off recently?
Randy
'87 911 Targa
'17 Macan GTS
Old 08-02-2007, 02:46 PM
rde rde is offline
Yes, dealer changed oil recently. But wouldn't too much oil have showed up as a problem right after the oil change? The smoking didn't start until after I installed the SW chip.
Old 08-02-2007, 03:27 PM
3.4 Bigger is better
88-diamondblue's Avatar
Email or give SteveW a call. His customer service and knowledge on this is second to none.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 08-02-2007, 07:41 PM
Jeff Alton's Avatar
Did you change the chip back to see if it cured the problems up?
Cheers
www.turn3autosport.com
Old 08-02-2007, 08:33 PM
MBruns for President
JeremyD's Avatar
Did you take the catalytic converter off when you installed the chip? Sometimes (it did with my car) the catalytic converter can mask the smoking at start up and leaving from a dead stop (after being run hard)
Mine ended up being worn valve guides (at 56,000 miles)
Old 08-03-2007, 06:25 AM
Make Bruins Great Again
Por_sha911's Avatar
Check your oil just to rule that out. Then switch back to the stock chip and see if it goes away. Lastly, call Steve. He's a great guy and will bend over backwards to make sure you are happy.
Joe
Old 08-03-2007, 04:42 PM
