Looking to clean up wiring in engine bay, help?
I am wondering where I should start looking for a good color coded wiring diagram for the engine bay area of my 77 911? The wiring has been doctored a few times by the PO's and I would like to clean up the mess. I figured now would be the time while the engine is out...
I'm mainly just trying to figure out what does what so that I can isolate what I do and don't need from this mess. Any help is appreciated! |
Happiest when Tinkering
he haynes 911 repair manual has color coded wiring diagrams should be able to order one from your local auto parts store.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
You also need to see an underhood restoration job thread done by Fishcop here. If I remember correctly, he installed a replacement modern fuse block and generally cleaned up his entire front wiring system, including paint. Truly impressive and though labor intensive didn't look all that difficult. Anyway, do a search for "Fishcop" as the author.
Dan in Pasadena '76 911S Sahara Beige/Cork |
Check out the wiring diagrams on the home page here. If I remember correctly those are color coded & probably cover your car.
Marv Evans '69 911E |
