deathpunk dan's Avatar
Spark plug gap question
Hello
Changing the plugs yesterday, I noticed that the manual specifies plug gap of 0.024. The WR5DC+ plugs (recommended by PP and others) have a gap of ~0.032. I assume this is acceptable or that a note to re-gap plugs before installation would be made somewhere...
Stock 2.2t engine with bosch distributor/crane ignition, if that helps.
One of the old NGKs I pulled out had a badly cracked insulator. Yikes.
Sepia brown 1971 911T.
Old 08-20-2007, 05:59 AM
Bug Eating Member
frogger's Avatar
I would use the factory spark plug gap specs unless your car has an MSD box instead of the factory CDI box.
Old 08-20-2007, 06:35 AM
Regis turd ab user
.028 - .032 should do you fine, NGK BP6ES or BP7ES depending on your operating conditions.
Old 08-20-2007, 06:57 AM
Mine are supposed to be .028, I have them at .035" and love it. No more gas smell at idle and no little backfires when letting off the gas.
Old 08-20-2007, 07:54 AM
With an upgrade to an HEI distributor cap/ ignition cables, my 86 3.2 has no problem firing a 0.060" gap.
Old 08-20-2007, 08:33 AM
Off a Jeep, right?
Hows that working for you?
I still have the bookmark somewhere.
Old 08-20-2007, 08:43 AM
That's right. An HEI Jeep Cerokee cap and rotor.
I have to admit that it's probably the most reliable ignition upgrade that I have ever had on my 911. Seems like I never have to worry about ignition issues ever again even after degreasing/hosing it off, it never skips a beat.
Nothing like having the reliability of a domestic with the performance of an exotic. Whoever said "you can't have your cake...."?
Cheers,
Joe
Old 08-21-2007, 07:17 AM
So your using the coil pac built into the cap?
I did this method on my 87 Wangler using a GM HEI. Sounds like a nice upgrade for the Porsche.
Silver 1980SC Euro coupe
Old 08-21-2007, 11:55 AM
What this forum needs is more pictures, don't you agree?
Sorry for the dirty engine, but as you can see this was before I installed the waterproof HEI cap. Now I don't worry about hosing my engine when I degrease it like I do on my domestic cars.
HEI cables
Water cooling.
Old 08-21-2007, 03:34 PM
