A/C Condenser Question -- Mr. Sims, are you out there?
I'm considering adding another condenser and fan to my a/c system. The condenser I'm considering has #6 and #8 o-ring fittings. Does it matter which is used for input and/or output? My instinct says the larger fitting should be for output, but I have no specific knowledge to back that up. So, what say you a/c experts -- which fitting is the "innie" and which is the "outtie?" Does it matter?
Thanks!
1984 Targa Last edited by scottb; 08-20-2007 at 09:38 PM.. |
Scottb,
Have you done the subcooler as Jim and hugh R talked talked back then? Any comment?
Fat butt 911, 1987 |
I did a ProCooler, and am very happy with the results.
1984 Targa |
why did you do procooler? Why didn't you do the subcooler so that you can give me some opinion?
Fat butt 911, 1987 Last edited by rnln; 08-20-2007 at 10:21 PM.. |
Throw it on the ground!
Scottb, I've got a ProCooler question for you. When you open your system up to add a 4th condenser, will you have to replace your ProCooler like you would a normal drier?
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 08-21-2007 at 02:58 AM.. |
Scottb,
With a condenser, you are hoping to go from hot gas to hot liquid, so the volume rate IN is higher than the volume rate OUT. So, #8 IN, #6 OUT. |
Mark: Good question! My hope is that I won't have to replace it if I seal off the system quickly with some duct tape. At some point I'll contact Ron Maxwell at Rennaire and ask him.
1984 Targa |
Scott
1984 Targa |
Great.....the answer will determine whether or not I do my [evap and front condenser replacement/ Procooler addition] and [underbelly condenser addition] at the same time. Probably best to push the entire project to the winter and do it all together when the A/C is not being used.
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
I already asked the question because my compressor went out about 6 months after I did the complete barrier hose/procooler replacement.
Ron said it would be fine for a day or so and it was. I capped the hoses to the compressor during the replacement and have had no issues. |
I asked Ron about this as well and the replacement cost is very very low assuming you have proof of purchase. But there again it can probably stand a couple "openings" as long as you cap the hoses so it's not exposed to air too long. On a side note - Where is Jim. He hasn't showed his face on any of the AC posts in quite some time. Maybe he's just on vacation
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
I would have speculated that it would be fine provided that 1) the system was in tact before being opened - no leaks to let air/moisture in 2) that once the system is opened the exposed ends are capped reasonably well and 3) you pull a good vacuum on it before recharge to remove any water vapor that did get in. Of course here in Arizona we are a lot less worried about humid air!
But it's good to have the expert opinion from Ron. It's also good to know that the replacement cost is low if/when it does need replaced. I never thought to ask that question when I bought mine. Although I'm sure it's written somewhere in the paperwork.
1986 Carrera Coupe 1999 Chevy Tahoe 1987 Chevy Blazer 1955 Chevy Apache 3100 Pickup "A little knowledge is a dangerous thing" |
A/C Condenser in FRONT of Rear Tire? Big fitting in, small fitting out....works just like your body (for most people) Also, no need to replace the dryer, just put the caps on as soon as you get it off, store in a cool dry place and don't install till your ready to pull a vacuum. And finally take many pictures.
Bill 1987 Marine Blue 911 Carrera Coupe RIP 01/2011 1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint |
YES, Take lots of pictures for us visual learners!!!
1995 993 Carrera, Guards Red Coupe (current) 1987 911 Carrera, Marine Blau Metallic (06-08) Gone but... 1965 Yellow Mustang Convertible (65-05) __________________________________________ It is always a good idea to keep the pointy end going forward as much as possible. |
Well, you got me thinking at least. But don't hold your breath....there's no way I'm going to mess with the system until we're deep into the winter months.
1984 Targa |
Slippery Slopenose Victim
I shot him a pm about an a/c question and no reply , he's normally very prompt .
sxsman@hotmail.com Have guns , will travel Mr. Potato-head , 1974 911 Slant/turbo look 2.7 1963 Cooper S ex-C sedan , 1974 Vespa Rally , 1974 TVR 2500M (sold) ( Musta had massive head trauma in 74 , ya think ? ) |
I have been traveling and have been "off the net." As stated before, the larger condenser fitting is the the inlet. I have seen some condensers that use two #8 fittings. It is generally better to install a condenser so that the outlet is lowest as installed and operated in the car; this is to enable better gas liquid separation.
Great to have you back.
It has been strange not havening your name pop up of the millions of summertime AC questions AND It's been hard on Scott fielding all of the questions
