| AutoBahned |
			Gorgeous!  Is there any way to design an air filter that allows people to see the trumpets?
|  09-02-2007, 04:35 PM |
| Senior Member Join Date: Jan 2001
			You could run those fine mesh wire screens right on top of the trumpets.  I've never used them so I don't know how well they work.  Too course a mesh and you would only be filtering large debris, too fine and I don't think it would flow very good because of the limited surface area.
|  09-02-2007, 07:42 PM |
| Registered Join Date: Jan 2003 Location: Langley,B.C.
			I think the mesh would restrict flow quite a bit.  Cut it all aparts and make the mesh solid and see how big it the piece would be..... Call you tomorrow Mark. Cheers
				__________________ Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 | ||
|  09-02-2007, 07:50 PM |
| Registered |
			Great work, Mark!   You could always make the top cover out of 3/8" Lexan to display the 'works" ...
				__________________ Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' | ||
|  09-02-2007, 09:34 PM |
| Author of "101 Projects" |
			As usual, very nice looking... -Wayne
				__________________ Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports | ||
|  09-02-2007, 10:41 PM |
| Registered Join Date: Jul 2005 Location: Yorkshire UK
				 | Quote:
 How is the idle air flow set? is there air bleed screws or is it via a throttle stop screw type arrangement? Steve
				__________________ 1972 911t RS Styled G50 conversion underway 1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695 | ||
|  09-02-2007, 11:03 PM |
| Registered Join Date: Mar 2006 Location: Sydney, Australia
			Has anyone here tried running factory motronic with ITB's? I was thinking of a map-ecu device to allow map input instead of the AFM. I'm pretty sure this will work - my bigger question is how big can one cam the motor and still use map sensor input rather than TPS only?
				__________________ Earlysport _____________________________________ 69 911E, 69 911E RS Rep 3.0L Hotrod, 77 930 IROC REP 3.6L SOLD, 968CS SOLD, 987 Boxster S SOLD | ||
|  09-03-2007, 11:23 PM |
| I hate freight charges |
			Wow, just wow. I want.
				__________________ Tom 78 911SC SC to 73RS imposter SCWDP crew #50 and 51 1969 Camaro "The new project"   | ||
|  09-03-2007, 11:26 PM |
| Irrationally exuberant | Quote:
 -Chris
				__________________ '80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ | ||
|  09-04-2007, 04:22 AM |
