AutoBahned
RWebb's Avatar
Gorgeous! Is there any way to design an air filter that allows people to see the trumpets?
Old 09-02-2007, 04:35 PM
Senior Member
Natchamp's Avatar
You could run those fine mesh wire screens right on top of the trumpets. I've never used them so I don't know how well they work. Too course a mesh and you would only be filtering large debris, too fine and I don't think it would flow very good because of the limited surface area.
Mark
The Beast
mark@hargett.com
www.HargettPrecision.com
Old 09-02-2007, 07:42 PM
Jeff Alton's Avatar
I think the mesh would restrict flow quite a bit. Cut it all aparts and make the mesh solid and see how big it the piece would be.....
Call you tomorrow Mark.
Cheers
www.turn3autosport.com
Old 09-02-2007, 07:50 PM
Early_S_Man's Avatar
Porsche Crest
Great work, Mark!
You could always make the top cover out of 3/8" Lexan to display the 'works" ...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-02-2007, 09:34 PM
1972_911T's Avatar
Originally Posted by Natchamp View Post
Hi Steve,
What ecu are you planning on running? Most NA systems are TPS based while MAP based are usually used on forced inducted motors.
Im planning on using MS, originally I was just going to run PMO'S as ive seen so many people try MS and end up ripping it all out for PMO's but recently there seems to be quite a few people actually getting it to work.
How is the idle air flow set? is there air bleed screws or is it via a throttle stop screw type arrangement?
1972 911t RS Styled
G50 conversion underway
1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695
Old 09-02-2007, 11:03 PM
Has anyone here tried running factory motronic with ITB's? I was thinking of a map-ecu device to allow map input instead of the AFM.
I'm pretty sure this will work - my bigger question is how big can one cam the motor and still use map sensor input rather than TPS only?
Earlysport
_____________________________________
69 911E, 69 911E RS Rep 3.0L Hotrod, 77 930
IROC REP 3.6L SOLD, 968CS SOLD, 987 Boxster S SOLD
Old 09-03-2007, 11:23 PM
I hate freight charges
village idiot's Avatar
Send a message via Yahoo to village idiot
Wow, just wow. I want.
Tom
78 911SC SC to 73RS imposter SCWDP crew #50 and 51
1969 Camaro "The new project"
Old 09-03-2007, 11:26 PM
Irrationally exuberant
ChrisBennet's Avatar
I don't know if anyone is running Motronic & MAP with ITB's but Protomotive in Florida has a MAP conversions for turboing 3.2L's. The difficulty lies in reprogramming the CPU. People often assume that they can use something to mimic the OEM air meter (and internal temp sensor) and then tweak a map or two in the CPU. That's a little like assuming that if you took something in French and replaced every word with the English word that you would have a translation.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 09-04-2007, 04:22 AM
