Senior Member
ITB's Anyone ?
Hey guys,
I've been developing a new product and wanted to share. I'll be debuting them at my booth at the GAF next week in Ventura. I just thought my fellow Pelicanites might want a sneek peak. Cheers! ![]() ![]() ![]() ![]() ![]() ![]()
Are you ready to post specs? If you are, please. If not I will see you at GAF.
I'll see you at GAF anyway!
Senior Member
These ones have 48mm butterflies tappered down to 40mm ports. The trumpets are also CNC tappered, all the shafts are ball bearing supported, etc. The air cleaner is integrated as well as TPS provisions. I haven't really put together a comprehensive spec list yet, hope to have it by the show.
Wer bremst verliert
nice! pricing and availability?
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
What are you using for linkage? Have you thought about moving the injector up a little in the manifold?
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Mark love them they look great.. What kind of price point on those?? Any luck on your turbo mufflers?
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
I am thinking they would be fun for turbo application as well
(the shotguns)
i vote 'ban' if no specs or pricing info is posted within 48 hrs!!!
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Irrationally exuberant
Mark you are such a tease!
They look great! -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
They have a definete grace to them that is for sure, look very nicely finished! Any shots of the throttle plates?
cheers
Metal Guru
Ben, great minds think alike
![]() Mark, those are beautiful! By the way, what happened with your semi-auto transmission project?
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
Senior Member
Thanks guys,
turbo version ? definitely in the works. I want a set for my car! linkage? I have a couple draft designs, haven’t decided which one yet. availability? Imminent high injectors? Maybe an option if there is enough demand pricing? Less than TWM’s but much better quality |
Senior Member
Jeff, here is a shot from the top. It didn't turn out very good because of all the flash wash. They really do look much better in person.
I would rather be driving
Those are very nice. I am interested to hear more.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Mark, those look great!! Lesst than a set of TWM's?? I have Jenveys's right now but will retrofit and give you dyno results if you want!
Are the fuel rails -6AN? Cheers
Senior Member
Yes, less than TWM's and keep in mind these are not cast. everything is machined, the throttle bodies and even the trumpets are all 100% CNC'd.
Here's another design aspect that I am proud of. The trumpets are extreemly easy to change. They actually screw into the base plate. So, different legths can easily be adapted for different applications. For example, a racer might want a shorter stack for a high-end track like Willow and a longer stack for a grunt track like Sears Point. ![]() ![]()
I am assuming you can make them for different intake port sizes for the various heads as well?
Very nice idea with the trumpets! Cheers
Suscribed!!
Ok as im about 2 weeks away from buying set of TWM's this thread couldnt have come at a better time, and hence I have some questions. I know high butterlies are good for high RPM race engines but what about street motors? will driveability be poor with the high butterflies? Will high butterflies cause any issues using a MAP sensor based FI system? and do these intakes come with vacume ports for such sensors?
Thanks Steve
1972 911t RS Styled G50 conversion underway 1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695 |
Senior Member
Hi Steve,
These will work great for the street and driveability would be excellent along with throttle response. They do have vacume ports (below the butterflies) for MAP sensors. Each throttle body has a port so you can gang them to even out the signal. What ecu are you planning on running? Most NA systems are TPS based while MAP based are usually used on forced inducted motors. |
