DGL DGL is offline
Basic Wire Splicing?
OK so this might seem like a little thing but those are the ones that always seem to get me in the end.
What is the "right way" to splice into turn signal/tail light wires? I am installing trailer wiring (for a mini track tire and jack trailer) and I want to make 100% trouble free, never have to think about it again splices.
The wiring kit came with squeeze down connectors similar to these:
First of all they look really bad and second I am pretty sure using these will have me doing a pocket knife and racers tape repair in a McDonald's parking lot during a thunderstorm and while such stories of my misery are always a hit at happy hour I would just assume not.
Anyone have a trade secret, never fails wire splicing formula they care to share?
Old 09-09-2007, 05:48 PM
"O"man(are we in trouble)
widgeon13's Avatar
soldering is the best in my book and then shrink tubing to cover the splice, it's strong, reliable and lasts and is very neat. I hate those cheap plastic things and you're right about doing a repair in some parking lot with thunder banging in the background and rain coming down like cats and dogs.
Old 09-09-2007, 05:56 PM
one of gods prototypes
bell's Avatar
don't use scotchlock type connectors......they will eventually fail and sometimes break the wire it's tapped into.
i would strip back the wire to be tapped, use a test light or pick to separate the wire which you will wrap your added wire through, then wrap it around tightly and tape, put a zip tie around the tape and splice and it will never ever fail.
you could solder if you want a permament connection.
Brought to you by Carl's Jr.
Old 09-09-2007, 05:57 PM
ianc's Avatar
You're right about that rubbish pictured at top.
A second on the soldering and heat shrink tubing. Can't fail,
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 09-09-2007, 06:49 PM
Solder.
Then use "liquid electrical tape" over the joint to prevent moisture.
Then use heat shrink tubing with an adhesive center.
'85 911. White - 53,000 miles bought 3-16-07. "Casper"
'88 924S. Blue - 120k miles bought with 105k miles.
'94 968 Coupe - White - 108,000 miles bought 9-28-17
'09 Cayman - Grey - bought 9-8-20
Old 09-09-2007, 06:53 PM
HarryD's Avatar
Try this thread for some ideas: Wiring question, solder or butt connectors?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 09-09-2007, 07:45 PM
LakeCleElum's Avatar
I've used those crap connectors and a year or two down the road, had the main wire break........Then I'm TU..............
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 09-09-2007, 09:08 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
Scotch locks are good to get you back on the road if you break down somewhere, and then promptly repaired correctly when you get home!
burgermeister's Avatar
Previous posts said it all....
If it's inside the car, you could use a crimp splice and run a pigtail off one of the ends - but it's almost as much work as soldering, and still not as good.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 09-10-2007, 01:55 AM
for entertainment
In one of my marine wire books...marine ABYC standards is satisfied w/quick connections if it will stay together with a 10# pull on #18 wire and a 40# on #10 wire pull or more. And have a voltage drop of under 50mV w/a 20 amp current.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-10-2007, 04:52 AM
DGL DGL is offline
Thanks for the information, I knew those things just didn't seem like a good idea.
The link to the previous discussion was also very helpful, not sure how I missed that one when I searched...
Old 09-10-2007, 07:58 AM
