Help please: body and engine codes
help appreciated in working out the following 911 chassis and engine codes please
Vin 9118310207 am i right in thinking this is a 1978 ROW 911 car is a coupe but i work the body code out to be a targa, any advice?? Engine 6380476 not sure if it is a 3.0l or 3.2l how to stupid people like me without limited knowledge tell the difference Urgent help please guys PS: still looking for RSR interior photos from an earlier post
Challenge your limits, don't limit your challenges 911 RSR Jagermeister replica (Sold) 1987 944 Turbo cup (Sold) |
sudo apt-get purge 930
Can't comment about the codes, I'm at work. It is a 3.0 though, 3.2 started in 1984.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
engine could be a later model than the chassis so dont let the chassis year influence your comments
True
911 = 911 8=1978 3=911SC RoW and Japan 1=Targa 0207 production sequence It is a RoW Sc with an engine type # 930/05 3.0 liter engine, 180 hp and 175 ft lbs. I don't have ROW engine numbers. Can't explain the targa/coupe numbers but you might double check that you haven't copied them down incorrectly: ie: 9118301207. Then you'd have a coupe. Check the number in the trunk by the smugglers box as well for a match.
Tony G 2000 Boxster S |
thanks Tony that was my first thought that I had the numbers down incorrectly which would explain the targa / coupe mix up.
With regard to engine, did you base you findings on chassis no which would mean this is what the car left factory with ie: 3.0l I think this car has had an engine transplant as the owner seems to think it has a 3.2l motor but he could be wrong, like me he has limited knowlegde, any easy way to tell the difference
According to the Red Book: 9118310001-9118311729 = 911SC Targa RoW, engine #6380001-on (930/03) 911SC RoW, all model year 1978.
thanks
post a pic of the engine. The 3.2's had a different induction system than the 3.0's. They use a motronic electronic injection rather than a CIS or continual Injection System. The intakes should tell something. It is possible that the original 3.0 motor has been built into a 3.2 with the original CIS injection, but no visual way that I know of to tell that.
photos of the 2 type of motors.
3.2 Carrera from 84 to 89 ![]() 3.0 SC motor
