KillerDynoSoar's Avatar
wind noise?
Not that kind of wind...
I have noticed that I get alot of wind noise and turbulant air when driving my 911 on the motorway/freeway. I have a lhd car and i get alot of turbulance around the back of the door window frame.
Is this normal? Do you guys have this issue or is there something I can do?
Al
77 Porsche 911 3.0 Carrera
58 Porsche 356
55 Chevy Bel-Air
72 Volkswagen Bug, 06 Volkswagen T5
14 Yamaha R1, 14 GSXR750, 17 CRF1000
Old 09-20-2007, 03:53 AM
AutoBahned
RWebb's Avatar
may be normal - several prev. threads if you search
Old 09-20-2007, 11:14 AM
Komenda Fan's Avatar
These are old cars with horrible (by modern standards) aerodynamics, hence they generate a fair amount of wind noise. Then as the seals age, they lose effectiveness, and the car gets noisier. My solution is a loud sport muffler and no sound deadening on the firewall - now I can't hear the wind noise!
2012 911 Black Edition Cabriolet
2008 Cayman S Grey on Black - flooded, written off
1977 930 Turbo Carrera Black on Red #411
1987 951 Black on Black - sold to make room for the 930
1972 911 2.7 - I regret selling her every single day....
Old 09-20-2007, 02:35 PM
Registered abUser
TerryH's Avatar
Do the dollar bill test. Close the door on dollar folded lengthwise. Slide the bill and try to find the gap. If the top rear window frame is not sealing, lower the door glass and gently bend the top rear door frame inward. Reference it to the rear 1/4glass before you start. Go at it slowly as it bends in slightly and should seal if that is indeed the leaking area. DO NOT do this with the window up/closed!
Bending the door top slightly often works better than messing with the door striker. This assumes your door weatherstrip is intact and resilient.
'81 911SC Coupe SOLD
Old 09-20-2007, 03:42 PM
Do what I did. Get a Cabrio!
Q.
2004 996 TurboS Cab
2005Cayenne Turbo S
1988 930 Turbo Cab
2004 BMW M3
2007 Range Rover Sport
Old 09-20-2007, 05:22 PM
Substitute a pound note... euro?
Old 09-20-2007, 06:00 PM
AutoBahned
RWebb's Avatar
The SC has an extra seal - not sure re your year.
Get an experienced mechanic or owner of multiple cars to ride along and see if your car is "normal for a 911" or worse.
There are numerous upgrades in either case - detailed in various threads. I'd start w/ the cheap & easy stuff. A Dane-like rain gutter removal would be last on my list. Other stuff in between.
A stehoscope can help you hunt down ingress locations also.
Old 09-20-2007, 09:39 PM
Shave your rain gutters...
86 Carrera
70 914-6
Old 09-20-2007, 10:20 PM
Thanks guys... I'll try seals and some light bending of the frame.
Al
58 Porsche 356
55 Chevy Bel-Air
Old 09-21-2007, 05:49 AM
