TERRIBLEHONDO's Avatar
1976 carrera
I know this might be a stupid question. But I see some conflicting information. Was a 1976 carrera made? What size engines did they come with a 2.7 or 3.0? Or do they come with either type? If it did come with a 3.0 is it the same as the 3.0 in my SC. Thanks hopefully you guys with more experience can help me out.
1997 328i convertible 1998 528I
Old 09-17-2007, 05:26 PM
durn for'ner
livi's Avatar
As far as I understand, the Carrera from 75-76 had the 3.0 L engine. Basically the same as the later SC.
I might be wrong though..
Markus
Resident Fluffer
Carrera '85
Old 09-17-2007, 05:30 PM
AutoBahned
RWebb's Avatar
2.7 in US
Old 09-17-2007, 05:51 PM
but a 76 carrera in the usa was not available.
as a euro/ ROW model it was available with either the 3.0 small flywheel end motor or the 2.7 mfi 911/83 RS engine.
The usa carrera was the turbo carrera in 1976= different kettle of fish
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 09-17-2007, 06:18 PM
klaucke's Avatar
Although both 3.0L and both using CIS induction, there were many differences b/w the Carrera 3.0 motor and SC 3.0 motor. Perhaps the biggest difference is the earlier style crankshaft (same as 2.7) that takes a 6 bolt flywheel. The SC uses the later 9 bolt flywheel. The bearing are different sizes and the cranks are not interchangeable. It is purported that the C3 motor is livelier and revs quicker, due to less rotating mass.
Old 09-17-2007, 07:32 PM
jackb911's Avatar
Also, the Carrera 3.0 was rated at 200 DIN HP, 20 more than the early 911SC's.
If my memory serves me correctly, early in the 1976 model year there were some "regular" 2.7 liter Euro Carreras built with the 911/83 210 HP engine.
Jack
2007 GT3
gone but not forgotten: 1987 Carrera IROC backdate, '89 Carrera M491, '96 993, '93 964 RSA(two), '00 996, '97 Boxster, '79 911SC, '78 928, '76 924, '75 914, '74 911, '74 914, '72 911E, '72 911T/V, '71 911T, '70 911T, '66 912, '65 356C, '61 356B roadster, '60 356B
Old 09-17-2007, 07:54 PM
Jubbie's Avatar
My understanding was the following:
74' and 75' had the MFI 2.7 Carrera with the short hood. In 75', there was a US Carrera which was a dressed up 911S.
76' and 77' was that the Carrera 3.0 was sold in not in the US. It was basically a CIS normally asperated (higher CR and differnt heads) version of the Turbo Carrera which had the same crank as the 2.7L but the stronger Al case.
78' came the SCs and the 3.3L turbo with the larger crank.
John F. Lewis
74' 911S Targa + 930/02
76' 914 - Eternal Type IV project FOR SALE
Old 09-17-2007, 08:38 PM
Bill Verburg's Avatar
there were 2 versions of Carrera offered in MY76, not counting the turbo Carrera
Both were RoW versions;
911.83 - MFI, 2.7, 210hp, 8.5cr
930.02 - CIS, 3.0, 200hp, 8.5cr
The 911.83 was first offered in the '73 Carrera 2.7RS as a long hood and was continued as an offering in MY74-76 w/ the short hood bodies
The 930.02 was the first street n/a use of the aluminum block and was a RoW MY76 & 77 offering only.
The '76 & 77 Carrera 3.0 morphed into the MY78 SC
the 930.02 used the 2.7crank, when the SC came out it used the beefier turbo crank but w/ smaller rod journals.
the 911SC 930.03/13/04/05/15/06/07/08/16/17 had the same8.5cr, heads and cams as the C3 but was rated at 180hp because of tuning
the 911SC 930.09/19 used in Row SC were rated at 188hp, again mechanically the same as the US/Cdn/J versions just different tuneing.
Bill Verburg
Old 09-18-2007, 03:49 AM
1976 carrera
OK guys thanks so if I understand it. There is no US version of a Carrera in 1976 only ROW. If someone has a Carrera here it was an import or home built. The ROW had 2.7 MFI and a 3.0 CIS and a regular 911 here had the 2.7 CIS. Is there a way of telling a 2.7 case from a 3.0 case visually or do you need to use the engine numbers? Thanks for any help.
Old 09-18-2007, 09:14 AM
The 2.7 has a mg. case w/ 911 part #(901 casting # is what is visable on the side of the case), the 3.0 has an al. case w/ 930 part#(and a 930. casting #)
At least most 2.7 had a mg. case there were a very, very few al. case 2.7
here is 1 w/ a 901. casting # visable
Bill Verburg
Old 09-18-2007, 11:57 AM
Thanks for the info I did not even know that the 2.7 could come with an aluminum case. I will just check engine numbers on the case.
Old 09-18-2007, 04:16 PM
sudo apt-get purge 930
equality72521's Avatar
Bill, will you be my personal Porsche expert? I will pay you nothing but sincere gratitude.
--clutch-monkey
Old 09-18-2007, 04:34 PM
Administrator
Jack Olsen's Avatar
Check the VIN, too. Pretty easy to tell from that.
Old 09-18-2007, 04:43 PM
equality I did not know Bob Marley and Turbos mixed
Old 09-18-2007, 05:35 PM
Ferdinand Magazine
johndglynn's Avatar
VIN, engine number or just put your foot down in fourth gear, no doubt about what is in the back when it starts picking up at 3700 revs
Sheriff at www.impactbumpers.com
Brand support at classicretrofit.com/tuthillporsche.com
1976 Porsche 911 Carrera 3.0: 'The Orange' - 1981 924 Turbo - 1983 944 Lux - Too many BMW motorcycles
Old 09-19-2007, 12:26 AM
klaucke's Avatar
As Bill V. said, an aluminum 7R case is very rare. I believe the only picture I've ever seen of one from taken by Steve Weiner. It would not have been on any late production 2.7, rather, it was almost assuredly a racing part. There's a good thread detailing Mg, Al, and Siluminum 7R cases on the Early S Registry.
Old 09-19-2007, 05:47 AM
al lkosmal's Avatar
does anyone know what cam towers, cams and heads the 3.0 carrera used? different than the SC?
RGruppe #669
http://www.x-faktory.com/
Old 09-19-2007, 06:14 AM
All the same as early SC
Cam timing was changed back and forth a few times between '76 & 89
Bill Verburg
Old 09-19-2007, 07:04 AM
They do in my world.
--clutch-monkey
Old 09-19-2007, 12:08 PM
EnlightenedOne's Avatar
my 76 carrera 3.0
some pics and the cars actually for sale around 13k area
Shes got b&b headders and exhaust as well. Couple of newer oil coolers and engine was once rebuild. Strong and fast.
Old 09-21-2007, 08:15 AM
