Otto's Avatar
Otto's has these in stock at $150.00 for a rebuilt exchange unit plus shipping.
The warranty is three years.
Racing Porsche for over 30 years.
http://www.OttosVenice.com
Check out the Porsche Owners Club Track event Videos
Old 02-22-2008, 08:38 AM
Wavey's Avatar
Uhh.... rebuilt by Loren, correct?
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 02-22-2008, 08:43 AM
abit off center
cgarr's Avatar
Rebuilt or repaired?
______________________
Craig
G2Performance
Old 02-22-2008, 08:57 AM
I've studied the board a bit more. Looking at the component side of the board with the connector to the right, the mosfet and capacitor in the lower left corner appears to be part of the sample/hold circuit. The cap is a high quality metalized polypropylene film capacitor 0.1ufd used in conjunction with a very high resistance input on the mosfet. I'm still not sure of the function of the coil immediately above the mosfet/cap, perhaps to filter the input.
The black rectangular box center right is a relay. The two chips are simple quad comparators.
The board appears to have been dipped in shellac. Nail polish remover seems to lift it nicely, but tends to remove some of the printed numbers on the parts.
I'm going to try building a test bed to bench run the board this weekend. If I can fake the board into thinking it is working, I'll be able to learn a lot more about how it functions.
Perhaps more information next week. I'll post what I learn.
Tim
1986 911 Cab
2008 Audi A6
Old 02-22-2008, 09:08 AM
Friend of Warren
Tim your tests are really going to help a lot of us that would like to keep their CC working.
Kurt V
Old 02-22-2008, 09:51 AM
I've been reading up on this a little bit at a time. I came across this site
http://www.pca.org/tech/tech_qa.asp
and this came up:
"I don't have a Bentley manual, so don't know what they left out. Here is a quick check of values at the plug to the control unit while plug is disconnected:
1. 11-17 ohms between 3 and 7. If not, check relay for continuity between 30 and 87a. If OK, servo is bad.
2. 12 is ground. Also, relay should activate when clutch is pushed. 12 is the ground side of the relay activation circuit.
3. Ohms between 11 and ground. Roll car. meter should deflect periodically. If the speedo doesn't work, no cruise
4. Open circuit between 6 and ground.
5. Turn key on. With brake pedal depressed, should have 12 volts between 6 and ground. If not, check brake switches.
6. 12 volts at 8 with switch lever up.
7. 12 volts at 5 with key on. If not, check fuse.
8. Ohms between 8 and 5. Normally closde, goes to open when switch pulled to off.
9. Ohms between 9 and 5. Normally open, goes to closed when switch pulled to set.
10. Ohms between 10 and 5. Normally open, goes to closed when switch pulled to reset. Failure of steps 8,9, or 10 indicates a bad switch. Failure of all three may also mean switch wiring disconnected. Print this out, write down what you get. Let me know if you have not found the problem. Good luck!
Chris Powell - PCA WebSite - 12/29/2005"
apparently our 911s (1984-89) use a 928 cruise control module. People looking into this might have some success using "928" under their search terms.
Old 02-22-2008, 10:23 AM
I started a new thread with current information
http://forums.pelicanparts.com/porsche-911-technical-forum/394659-understanding-vdo-cruise-control-amp-post3789513.html?posted=1#post3789513
Tim
1986 911 Cab
2008 Audi A6
Old 02-24-2008, 01:55 PM
dshepp806's Avatar
FINALLY: some schematics and one helluva discussion!!
Many thanks!!
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 02-24-2008, 03:01 PM
