Scott R's Avatar
OK, some folks are not going to want to read this, however I purchased a perfectly sorted CIS system last Monday. The system was installed today, and upon first start, it was perfect. Idle was perfect, warm up was perfect, driving was a xen like experience. I'll hit the dyno later this week and post the numbers. (looks like I'll have a complete EFI and LC1 system for sale.)
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-14-2007, 06:58 PM
Grady Clay's Avatar
Scott,
Please don’t give up so easily. I understand your frustration but it can be solved. I’ll volunteer to help. I have a ’74 Targa with a CIS 3.0 installed. It runs great. Rumor has it that it is a 3.2.
I’m willing to let it be a ‘mule’ for your EFI if you are willing. Unfortunately someone has my Stuska engine dyno without my permission. You (or others) will need to test in the Targa.
I’m willing to have a group effort to get this right.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 10-14-2007, 07:38 PM
never ending projects
niner11's Avatar
Glad you got it running but I'm wondering what size injectors you really had. Were they 42lb or no?
BTW, you might want to keep the LCI...those can be used on anything
Old 10-14-2007, 08:03 PM
Scott R's Avatar
Originally Posted by Noah View Post
Veeeery interesting...I'm curious to know too. Scott has portrayed his problems in this thread as having been constant. Something is strange here.
Oh, I completely agree, the solution should not have been this simple. I did go to great lengths to source a perfect CIS system; all but one injector passed my flow bench test, and I replaced that from my parts stock. This is a night and day difference, I need to start it cold this morning to be sure that the AAR is working, but that's about it.
Grady, I was going to dyno this setup, then based on that I was going to either go back to EFI or sell the system outright. However given how things are running right now, I can't see myself going back to EFI. If you want to test the system it's still complete as I removed it, right down to the airbox, so it's a bolt on and go.
Niner, how do I integrate the LCI to the Lambda brain? I was going to get a standard Bosch two wire analog unit today to complete the trasition, since I can't seem to find my original. Will the Lambda brain understand the wideband sensor?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-15-2007, 06:18 AM
niner11's Avatar
Scott, glad that you have the car running. I'm still learning about MS and yes it sometimes takes a lot of time to come up with a good map. I guess the secret is to mirror someone that has done a MSII conversion and then use their MSQ as a starting point. You might as well keep your MS stuff since they arent worth much used and you may find that you want to switch back at some point. Enjoy the car for now.
My turbo datsun was down for 4 or 5 months while I did a turbo motor swap with MSII so your issues are not unusual in the aftermarked EFI community. I will say the car runs great now using MSII for fuel and spark. Actually kind of fun to datalog and tune the car.
About the LC-1...innovate makes a tail pipe mount so I think so you can monitor your AFR's on just about any vehicle.
Old 10-15-2007, 10:24 AM
sjf911's Avatar
The LC-1 should have an analogue out (Analogue 1-yellow wire) that mimics your stock O2 sensor.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 10-15-2007, 12:06 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
The LC-1 has two configurable analog outputs. By default Analog out #1 is configured to mimic a narrow-band O2-sensor (step function) and Analog out #2 is a linear voltage ramp betweeen 0.0 and 5.0 volts corresponding to 8 - 20 A/F ratio. Both outputs can be configured. When using the LC-1 it is very important that the translation from A/F ratio into a voltage is configured in the same way the controller (e.g. MS-II, analog gauge) expects the data. Otherwise you will have scale and bias errors.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 10-15-2007, 12:37 PM
Scott R's Avatar
Between meetings I went down to the garage and re-connected the CSV, ran out of time last night. Sure enough she kicked right over and ran like a top. I need to complete the O2 sensor after my next meeting and I'll post up some AF's.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-15-2007, 01:33 PM
