safe's Avatar
Need help with advance curve for a 3.2
Hi
I recently bought a ROW 3.2 -85 long block. Until I get the funds for carbs or an ITB efi I will use a CIS system on it.
I've read that I can use a pre SC distributor instead of the original 3.2, and I might have one from a 71, but that I need a new advance curve on it.
The engine is stock otherwise with a 10.3:1 compression ratio and will run on equivalent 94-95 US octane gas.
I'm hoping someone here could suggest an appropriate advance curve?
Magnus
Old 10-21-2007, 05:28 AM
Early_S_Man's Avatar
Porsche Crest
Magnus,
The distributor will have to be a 2.4 or later unit due to a larger bore in the case for the '72 models and forward.
The choice of a stock advance curve seems to be problematic, considering the 10.3:1 compression ratio ... maybe a 1969 911S derated, or retarded 3° - 5° could work?
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 10-21-2007, 05:46 AM
safe's Avatar
OK, a 2.4 or a 2.7 distributor then. I didn't know they changed the bore in the case, thanks.
It doesn't need to be a stock curve, just one that will work, I can get it recurved locally but the guy needs to know what curve to use.
I was looking at what curve the motronic uses at full load (http://www.911chips.com/ignition.htm) and thinking that maybe around 25 degrees of maximum advance would work and give me some margin.
Magnus
Old 10-21-2007, 08:55 AM
safe's Avatar
bump, anyone else?
Magnus
Old 10-22-2007, 01:07 PM
here's a look at a stock map, don't know if this helps or not
Old 10-22-2007, 04:10 PM
