burgermeister's Avatar
external thermostat cap torque spec?
Anyone know the torque spec for the 2 slotted caps on the external thermostat?
Bentley only gives values for the oil line nuts.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 05-09-2010, 04:51 PM
Senior Advisor
James Brown's Avatar
just tight the sealing comes from the O rings not from the torque applied to the nut.
08 Cayenne Turbo
Old 05-09-2010, 05:22 PM
dshepp806's Avatar
For sure on that,..they're easy to break off if overtorqued.
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 05-10-2010, 03:57 AM
