external thermostat cap torque spec?
Anyone know the torque spec for the 2 slotted caps on the external thermostat?
Bentley only gives values for the oil line nuts. Thanks
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
Senior Advisor
just tight the sealing comes from the O rings not from the torque applied to the nut.
08 Cayenne Turbo |
For sure on that,..they're easy to break off if overtorqued.
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
