sealant between cam tower and heads
What do people use for this no-gasket interface? I am thinking blue Hylomar.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 10-24-2007, 08:22 AM
GotaT's Avatar
Send a message via AIM to GotaT Send a message via Yahoo to GotaT
I use Red Anaerobic Sealant, others use Loctite 474.. basically the same or Threebond 1131 or 1121 cant remember the #.. Pelican sells any of them.
Old 10-24-2007, 08:46 AM
Slippery Slopenose Victim
SXSMAN's Avatar
In Waynes engine rebuilding book ( a good book and value for the money ) loctite 574 is recommended .
I have a question into Loctite Corp about the same question right now .
Our shop has been using Loctite 518 sealant for a few years with great results .
Both 518 and 574 are medium strength adhesives and are Anaerobic in nature .
I sent Wayne a PM and he replied that 574 is what Porsche recommends but felt 518 would also be fine .
We ( our shop ) has had problems with Hylomar and is the main reason we went to 518 .
You may also want to ask over on the engine rebuilding forum also .
SxS
sxsman@hotmail.com Have guns , will travel
Mr. Potato-head , 1974 911 Slant/turbo look 2.7
1963 Cooper S ex-C sedan , 1974 Vespa Rally , 1974 TVR 2500M (sold) ( Musta had massive head trauma in 74 , ya think ? )
Old 10-24-2007, 08:51 AM
Irrationally exuberant
ChrisBennet's Avatar
I've used Loctite 518 (fills bigger gaps than 574) and ThreeBond 1104 (aka Yamabond) with good results. Loctite 518 is the red anerobic sealant GotaT refers too.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 10-24-2007, 09:28 AM
resident samsquamch
sand_man's Avatar
ThreeBond 1104 on mine; what Neil Harvey of Performance Developments uses, in this area. I also used it to seal up my case.
-jeff
Old 10-24-2007, 09:46 AM
I just picked up a 3.6l motor with a dripping leak when the motor is tilted on it's side on the engine stand like this. ->
Is this the location you are talking about? ->
Looks like it's time to go to work on the new engine.
1981 911sc RoW Coupe (forever under 3.6L conversion)
2003 996TT Basalt black
Old 10-24-2007, 09:47 AM
No, that is not the location.
it is the interface between the heads and the housing where the rocker arms and the cam shaft live. 6 heads and 2 housings, making a total of 6 surfaces to seal.
Old 10-24-2007, 09:58 AM
Ok I understand where you are talking about now. Sorry to be off topic, but how do I fix my leak?
Old 10-24-2007, 10:10 AM
304065's Avatar
574. There's an extensive thread on this in the engine rebuilding forum.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 10-24-2007, 10:38 AM
Remove the timing chain housing, reseal with new gasket and some dressing material like T-curil.
Old 10-24-2007, 10:51 AM
Now in 993 land ...
aigel's Avatar
Jerry Woods uses Dow Corning 730. Overall I lean towards his way of sealing engines over Wayne's, but I'd hate to shell out the dough for the DC730 and would go with the Loctite 574. It's worked well on the few rebuilds I helped with. Here a good compilation:
Lubes, sealants and different approaches...
George
81 SC (sold)
