first engine drop - clutch prob
Hi all,
Thanks for guiding me trough my first 911 engine drop.
It took me 3 hours completely on my own...here is the pic
The reason for this engine drop is my "sticking clutch " problem: engine and tranny cold, the clutch don't gets disengaged. After 50 m driving everything is OK.
This is what I found after dismantling the clutch components:
Rusty splines, wear on the TOB outside has touched the guide tube, wear on the inside...
What do you think?
Tx,
dede
Old 10-28-2007, 10:00 AM
Somatic Negative Optimist
Gunter's Avatar
Complete new clutch components, I recommend the light-weight sports package.
New cable.
New guide tube and seals/O-ring in the transmission.
New seal for the input shaft.
Good time to change transmission oil.
New main seal (Engine)
If the flywheel needs a grind, consider making it lighter by machining portions out of it.
I think Henry Schmidt, or Steve Weiner, does it? A re-balance, of course!
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 10-28-2007, 11:28 AM
AutoBahned
RWebb's Avatar
clean up the rust and examine the splines carefully - prob. ok. see if you can post a macro pic that is in focus (borrow a camera?; more light; tripod)
obviously it was w/o grease
-replace TO bearing and typical 'while you're in there' type components
- bush sand surface rust off of PP
- examine clutch disc for wear
- check flywheel surface
- maybe just replace the clutch cable anyway
best to have 2 adults to put motor back in
how is the clutch pedal actuation itself?
Old 10-28-2007, 11:29 AM
Zeke's Avatar
Quite distance from Belgium.
Old 10-28-2007, 12:35 PM
Gunter's Avatar
Yeah, nice country and I remember Spa and Porsche-racing.
Should have been more precise.
I mean H. Schmidt and S. Weiner could provide details on how to lighten the flywheel.
There was a post showing how sections of the flywheel were machined to reduce weight.
I'll do that next time the engine is out.
Old 10-29-2007, 08:31 AM
