1st time removing an engine, any advice..
This will be the first time I remove an engine from a car (79SC). I've already gone over Wayne's book as well as the tech article on Pelican. Just wondering if anyone can offer any suggestions on what I should look out for, and what I should replace while the engine is out. Planning on putting the EGR on, valve adjustment, and check for leaks.
Thanks |
I found it easier to remove the rear bumper, you won't have to jack up the back end as high. Only takes 15 minutes, worth the time.
1983 911 SC 2015 Volks GTI 1991 Volks GTI 2011 Nissan Juke 1992 Nissan NX 2000 |
oil temp sender gasket.
oil cooler gasket brass fittings for your pedal linkage check and replace clutch/ fork/ etc. replace fluid as well. a few more I can't think of right now.
1982 Porsche 911SC Coupe - Factory Short Shift |7:31 R&P in AL case | Toyo RA1 Tires | Corbeau TRS seats | M&K 2 in 2 out muffler |
