I have it in my notes that the 930 trailing arms extend each side by 22mm. My source was this post.
Ill look through the source documents to try to find where that # came from. It was all soooo long ago.
Pelican Parts Vendor
Paul Eddleston BRAID Wheels USA Team Illuminata Motorsport Last edited by BRAIDusa; 03-09-2015 at 07:23 PM.. |
This isn't 100% accurate because track changes w/ height change but starting w/ stock height rear track for a 911 & 930 in mm 1380 1501 spacers 0 56(2x28mm) subtract 1380 1445 measuring wheel ET x2 911 has 7ET 23.3 930 has 8ET 10.6 46.6 21.2 subtract 1333.4 1423.8 result 90.4mm difference in wheel mounting face divide by 2 45.2mm /side My guess is that is comprised of 33mm wider trailing arm + 22mm wider pickup points
I'm thinking of installing the same naked wheel on my 84 Carrera and my friend's 88 930 and measuring back to the inner wheel well wall. That should be fairly definitive don't you think?
Paul Eddleston BRAID Wheels USA Team Illuminata Motorsport |
Bruce Andersons book has info about the diffrent pickup points
82 SC , 72 914 |
It's clear that there are several causes for the wider track, I rethought the process of using the rear track 911 930 1380 1501 rear track in mm at std ride height 690 750.5 1/2 so we are only dealing w/ one side 0 28 spacers 690 722.5 subtract the spacers to get to the wheel mounting face 23.3 10.6 7" & 8" wheel ET, these are positive(ie move the wheel ctr line inboard) and need to be added to the above to eliminate them 713.3 733.1 this is the distance from the center line of the car to the wheel mounting face the difference is 19.8mm/side, i.e. the 930 wheel mounting face is 19.8mm further out board This makes sense because the fenders were extended 2"/side, the 19.8 + a 28mm spacer moves the 8" wheel 1.95" outboard to fit the 930 fender
Thanks Bill.
It will be interesting to see the actual measurements from a 930, please let us know
88 930: 84 Carrera: Using the same wheel on both cars I measured back to the inner fender wall. 930 is 88mm, Carrera 67mm. Difference is 21mm. Less than I expected. Perhaps I should have used the same tape measure.
Thanks for settling this!
Shall we declare it "so"?
