Ferrino's Avatar
I have it in my notes that the 930 trailing arms extend each side by 22mm. My source was this post.
Old 03-09-2015, 02:35 PM
Bill Verburg's Avatar
The pick up points were moved outboard 22mm, the 930 arm needed to be shorter to compensate, but when I looked into this I found the wheel mounting face was 33mm outboard.
Ill look through the source documents to try to find where that # came from. It was all soooo long ago.
Bill Verburg
Old 03-09-2015, 03:11 PM
Pelican Parts Vendor
BRAIDusa's Avatar
Originally Posted by Bill Verburg View Post
Yes, each side of the rear 930 pushes it's wheel out 1.3"(33mm) more than a 911.
Then they added 28mm spacers to that so that they could use the same wheels as were used on the 911.
in the front of a 930 they use a 21mm spacer, till '80 it was a removable spacer, from '80 they increased the hub o/s 21mm
Thanks Bill. That's great. I had the spacer thing down but the arms were throwing me off.
Paul Eddleston
BRAID Wheels USA
Team Illuminata Motorsport
Old 03-09-2015, 03:47 PM
I can't find the source material but another way to find that # is to start w/ the factory rear track #s
This isn't 100% accurate because track changes w/ height change but starting w/ stock height rear track for a 911 & 930 in mm
1380 1501
spacers
0 56(2x28mm)
subtract
1380 1445
measuring wheel ET x2 911 has 7ET 23.3 930 has 8ET 10.6
46.6 21.2
subtract
1333.4 1423.8
result 90.4mm difference in wheel mounting face
divide by 2
45.2mm /side
My guess is that is comprised of 33mm wider trailing arm + 22mm wider pickup points
Bill Verburg
Old 03-09-2015, 03:52 PM
BRAIDusa's Avatar
1380 1501
spacers
0 56(2x28mm)
subtract
1380 1445
46.6 21.2
subtract
1333.4 1423.8
divide by 2
45.2mm /side
45mm seems like a lot.
I'm thinking of installing the same naked wheel on my 84 Carrera and my friend's 88 930 and measuring back to the inner wheel well wall. That should be fairly definitive don't you think?
Paul Eddleston
BRAID Wheels USA
Old 03-09-2015, 06:27 PM
Bruce Andersons book has info about the diffrent pickup points
Old 03-09-2015, 06:37 PM
I'm still looking for the original source material
It's clear that there are several causes for the wider track,
I rethought the process of using the rear track
911 930
1380 1501 rear track in mm at std ride height
690 750.5 1/2 so we are only dealing w/ one side
0 28 spacers
690 722.5 subtract the spacers to get to the wheel mounting face
23.3 10.6 7" & 8" wheel ET, these are positive(ie move the wheel ctr line inboard) and need to be added to the above to eliminate them
713.3 733.1 this is the distance from the center line of the car to the wheel mounting face
the difference is 19.8mm/side, i.e. the 930 wheel mounting face is 19.8mm further out board
This makes sense because the fenders were extended 2"/side, the 19.8 + a 28mm spacer moves the 8" wheel 1.95" outboard to fit the 930 fender
Bill Verburg
Old 03-10-2015, 05:11 AM
BRAIDusa's Avatar
911 930
0 28 spacers
I like that more. I'm still going to measure when I get my hands on a 930 again.
Thanks Bill.
Paul Eddleston
BRAID Wheels USA
Old 03-10-2015, 05:30 AM
Thanks Bill.
Always best to measure
It will be interesting to see the actual measurements from a 930, please let us know
Bill Verburg
Old 03-10-2015, 06:26 AM
BRAIDusa's Avatar
Well, I think I did this right.
88 930:
84 Carrera:
Using the same wheel on both cars I measured back to the inner fender wall. 930 is 88mm, Carrera 67mm. Difference is 21mm. Less than I expected. Perhaps I should have used the same tape measure.
Paul Eddleston
BRAID Wheels USA
Old 03-14-2015, 05:45 AM
88 930:
84 Carrera:
That's darn good agreement w/ the 19.8mm that I came up w/ by comparing the track difference.
Thanks for settling this!
Bill Verburg
Old 03-14-2015, 06:06 AM
BRAIDusa's Avatar
Shall we declare it "so"?
Paul Eddleston
BRAID Wheels USA
Old 03-14-2015, 06:25 AM
