Member 911 Anonymous
DRACO A5OG's Avatar
Question Accelerator Bushings Replacement?
Parts 99992406900
Has anyone replaced these bushings? Any tips or tricks?
TIA,
Jim
'85 Carrera Targa
PCA/POC
Old 05-11-2011, 11:33 AM
DRACO A5OG's Avatar
Good God, that is a tight space, it looks like similar work to the Breather Gasket job. Great, time to stick my big Buddha head back there again
'85 Carrera Targa
PCA/POC
Old 05-11-2011, 12:14 PM
very easy
less than 10 min
1978 911sc cpe
1986 944 N/A sold to pelican
1965 series 2a 88 landrover sold
1964 series 2a 88 landrover sold
1988 944 white. sold
Old 05-11-2011, 12:22 PM
Originally Posted by landrover88 View Post
very easy
less than 10 min
Yea, right. It takes longer than that to get the carpets and the floor board out of the way.
One of the many jobs on my to-do list is replace the pedal bushings. I keep putting it off for some reason.
Old 05-11-2011, 12:26 PM
DRACO A5OG's Avatar
Oh no, not at the pedal but in the engine bay on top next to the Oil Breather below the Throttle Body.
At the Pedal and Bell housing are new.
'85 Carrera Targa
PCA/POC
Old 05-11-2011, 12:30 PM
Oh, OK. I did not look at the drawing close enough. Sorry.
Still no fun.
Old 05-11-2011, 12:35 PM
DRACO A5OG's Avatar
Joy
'85 Carrera Targa
PCA/POC
Old 05-11-2011, 12:39 PM
Fleabit peanut monkey
Bob Kontak's Avatar
If it were me, and I hate the tight spaces, I would drop the engine a few inches and get in there and pull the whole plate out. Replace the bushings on the bench and re-install.
Old 05-11-2011, 01:24 PM
DRACO A5OG's Avatar
Trying to avoid that but maybe a partial drop if push came to shove.
'85 Carrera Targa
PCA/POC
Old 05-11-2011, 02:28 PM
Canyon Runner
70SC's Avatar
Throttle plate Bushings
Don't drop the motor unless you feel the need . By the time you get the two mount bolts you could have lossened the one shaft bolt & removed the whole assembly . One tip for install ,Install inner bushing on the shaft & leave the outter bushing untill you insert the shaft in the first bushing .Now install the second bushing . Tighten the locknut , reinstall the linkage & Done Cake Did mine on my SC in .5 hr . Nice & positive .Don't forget the rubber coupler bushing on the linkage, By the trans mount plate . Nice fix for less than $45 Draco : a little tougher on the 3.2
Old 05-11-2011, 07:34 PM
DRACO A5OG's Avatar
All is fresh except the Throttle Body Bushing and I suspect right below the TB the two bushings at $7.50 each
'85 Carrera Targa
PCA/POC
Old 05-11-2011, 07:38 PM
