Member 911 Anonymous
DRACO A5OG's Avatar
Oh no, in my year there is a electronic terminal with 3 connections the can be unplugged to disable the ICV.
If you have the ICV, it will be on the driver side, simply unplug it, adjust idle then plug it back in.
'85 Carrera Targa
PCA/POC
Old 11-30-2007, 11:06 PM
Irrationally exuberant
ChrisBennet's Avatar
I don't think unplugging the ISV is going to get you what you want.
Simply unplugging the ISV will let the internal valve go to a random position - it isn't spring loaded or anything.
Jump the test socket with a piece of wire (see details elsewhere). This simulates closing (?) the WOT (wide open throttle) switch which in turn causes the DME (car computer) to use the map that ignores the 02 sensor and sets the ISV signal to the correct duty cycle for the test.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 12-01-2007, 05:14 AM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
see that is the problem for me.
I have been looking for the details elsewhere and just have not got my head around how to jump the test socket.
what type of wire?
how does it connect?
sorry if these sound like stupid questions
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 12-01-2007, 06:16 AM
1984-911 M491
Trog's Avatar
Courtesy of Steve W:
Old 12-01-2007, 07:19 AM
just me
paulgtr's Avatar
cool
tried that and the idle is steady sits between 1 on the tach
and the line below, so i imagine that is around 880.
next dumb question is regarding the CO setting using the meter to test off the o2 sensor.
how do I check that?
I don't know where to check the level
Old 12-01-2007, 08:08 AM
DRACO A5OG's Avatar
I ask the dealer to check CO levels the said go to a smog check station to check CO levels. Hopefully the vets can post in, I think the dealer has lost alot of credit putting in Synth Fluid in my 915 Trans with LSD. Expensive lesson learned.
'85 Carrera Targa
PCA/POC
Old 12-01-2007, 08:41 AM
rnln's Avatar
Not purposing to drive the topic off but since someone is talking about CO/CO2 level, does anyone know how much is at the acceptable level of o2/CO/CO2?
Fat butt 911, 1987
Old 12-01-2007, 11:53 PM
