-   -   Here we go again! Zuffenhaus MS RSR project... (http://forums.pelicanparts.com/porsche-911-technical-forum/379658-here-we-go-again-zuffenhaus-ms-rsr-project.html)
eimkeith 05-30-2015 05:56 PM
well, that was my first time in 43 years; but if it happens again, I'll certainly do that!
BTW, I love the waterfront there; coming out of the tunnel onto the bridge was like a miracle, I really enjoyed it. So industrial/gothic - there has to be some Southern undercurrent in the design there, very cool.
eimkeith 05-31-2015 08:26 AM
So I started working on a P852 windshield template this morning. I'm having trouble getting good references to the construction of the original tool, so I started with square tubing... May need to use solid bar instead.
Here's the P852:
http://images.tapatalk-cdn.com/15/05...db5f21c56e.jpg
http://images.tapatalk-cdn.com/15/05...7a0ddf975e.jpg
And here is my tube corner:
http://images.tapatalk-cdn.com/15/05...10256f2283.jpg
http://images.tapatalk-cdn.com/15/05...3a864f2c49.jpg
http://images.tapatalk-cdn.com/15/05...e258f2506b.jpg
I'm thinking I could control the cross section through the tight bend better with solid bar...
I'll be using these to verify windshield orifice dimensions when installing the early dash top and roof.
keith.
(sent from my rotary dial phone.)
Tom '74 911 05-31-2015 08:53 AM
Very interesting to see you tackle this... I just ordered some square tube on Friday to start this exact project... I think your finished templates are going to be far better than mine!
I have a few additional images of the templates which maybe you've seen already? Also, the Porsche factory restoration videos from when they restored the car they raffled off have some scenes where the templates are present...
My methods were going to be much more crude than yours... and I'm assuming that it'll take a lot of time & experimentation to get something that'll be worthwhile using in the end. Nice work on that first corner.
http://forums.pelicanparts.com/uploa...1433087523.jpg
http://forums.pelicanparts.com/uploa...1433087540.jpg
http://forums.pelicanparts.com/uploa...1433087555.jpg
eimkeith 05-31-2015 09:11 AM
outstanding!
those photos are really great - and making those door opening templates is going to suck! ;) (I'll save that for a later project.)
I'm in the market for these if any ever turn up for sale, btw.
Tom '74 911 05-31-2015 09:13 AM
Originally Posted by eimkeith (Post 8645263)
outstanding!
I agree 100% on the sucking comment! & I'd buy a set if I came across them too! Maybe we could go halfsies? : )
eimkeith 05-31-2015 09:24 AM
you're on - I'll take the front windshield, left door and quarter window ;)
jjeffries 05-31-2015 03:39 PM
How about making these in tow steps:
1. Form the basic piece out of round steel bar, easier to bend, with 1/8" clearance around each edge, then
2. Add 1/8" thick angle stock to fit around the outside and to create the actual edge; could be done in pieces, notched to make create corners.
Not the world's greatest description of an idea, hope you get the gist.
I've always thought these factory tools were the coolest thing, totally characteristic of Porsche philosophy. John.
eimkeith 05-31-2015 05:37 PM
not sure if that would account for the plane changes at the windshield edges and pinch weld flange; although I'd considered making it out of 2 runs of 3/4 angle to ease the construction (but double the work...)
It would be helpful to know if the factory tools are hollow or solid at the perimeter.
eimkeith 06-01-2015 08:15 AM
Ok, the bar seems to be the way to go (although more time consuming to heat & bend...)
http://images.tapatalk-cdn.com/15/06...1f98684f65.jpg
http://images.tapatalk-cdn.com/15/06...0e2095a348.jpg
keith.
rennch 06-01-2015 10:21 AM
Pardon my ignorance on this, but what does the square bar serve to do? What are you creating with this?
eimkeith 06-01-2015 12:36 PM
The green windshield template jig shown in post #443.
I've removed the dash from this car to replace it with an early dash core, which could possibly affect my cowl position (and consequently the windshield opening) when it is welded back in. I want to make certain the windshield seal won't leak, by making sure my windshield opening doesn't change. This template is just for that: verification of windshield opening dimensions for use when replacing the roof, cowl, or other major repair/panel replacement.
I ran out of oxygen on the torches, just shy of finalizing the corner piece:
http://images.tapatalk-cdn.com/15/06...7f247067c1.jpg
Not the best thing I've ever bent, but not too shabby.
keith.
cnielsen 06-01-2015 01:10 PM
These would be handy jigs as well...since the factory replacement quarters fit like a sock on a rooster!
http://forums.pelicanparts.com/uploa...1433189212.jpg
More pics of the factory units
http://forums.pelicanparts.com/uploa...1433189292.jpg
http://forums.pelicanparts.com/uploa...1433189339.jpg
eimkeith 06-01-2015 01:45 PM
Yeah, I'll be doing those also, in addition to the rear windshield and the doors.
keith.
eimkeith 06-02-2015 07:36 AM
Back at it.
http://images.tapatalk-cdn.com/15/06...0ac3171259.jpg
http://images.tapatalk-cdn.com/15/06...bc345a3c8f.jpg
keith.
jjeffries 06-02-2015 12:51 PM
Highly impressive. Some serious forces involved there, mechanical and temperature. John.
eimkeith 06-02-2015 04:44 PM
Thanks! this stuff takes me back to college:
http://forums.pelicanparts.com/uploa...1433288081.jpg
(I was doing stuff like this then)
OK, so I ran out of gas on the torches about the time the oil cooler modifications were done.
Remember the end-tank revisions necessary for correct through-trunk lines and bumper clearance?
http://forums.pelicanparts.com/uploa...1433288506.jpg
well, the revision worked out just fine:
http://forums.pelicanparts.com/uploa...1433288561.jpg
http://forums.pelicanparts.com/uploa...1433288598.jpg
Back on the windshield template tool tomorrow.
eimkeith 06-03-2015 02:48 PM
Made strides on the windshield template tool today.
http://images.tapatalk-cdn.com/15/06...c91f365f7c.jpg
http://images.tapatalk-cdn.com/15/06...99429dcac6.jpg
I got overzealous and finish welded my A pillar joint from the outside before tacking the inside of the joint and it drew on me a little (was pretty tight to the chassis beforehand) - not bad, but I'm hoping I can pull it back when I weld up the inside joint.
Aside from that, I have the passenger upper corner to touch up and cut in, and then I can finish the perimeter.
Then 2 more braces and I can get back on the Mary Stuart dash!
keith.
eimkeith 06-04-2015 01:32 PM
Ok, so the draw while welding was a setback. I had to cut it apart and make new vertical braces, clamp it up and do it over. Just now trimming in the passenger top corner.
keith.
eimkeith 06-04-2015 02:57 PM
All tacked up; one brace to go!
http://images.tapatalk-cdn.com/15/06...7af582c5e8.jpg
keith.
Tim K 06-04-2015 03:32 PM
Just so I understand, the later upper-dash sheet metal is different enough that it cannot accommodate the early dash? And you're drilling out the spot welds along the bottom of the window opening to R&R with the new one?
Also, are you removing the entire roof skin including the 'cowl', or just a panel to delete the sunroof?
Just trying to understand the concern over structural support.
Thanks for sharing your progress,
Tim K
