LinkBack Thread Tools Rating: Thread Rating: 11 votes, 4.09 average.
Brake line work has begun, new hard lines, using the old ones as templates:
Getting an idea of the bends to get the lines into the rack n pinion tunnel. This is the driver side:
Passenger Side:
Main line flared and finished:
14 Cayenne Turbo S
06 Cayman S
87 911 becoming 73 RSR Mary Stuart
68 TVR Tuscan LWB
66 TVR Griffith Series 400
Old 02-02-2024, 04:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #881 (permalink)
Feed Line for the brake splitter:
Pics of the original lines/brake/clutch masters for reference:
Two views of what we have so far:
14 Cayenne Turbo S
06 Cayman S
68 TVR Tuscan LWB
Old 02-02-2024, 04:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #882 (permalink)
Parking brake handle arrived today for restoration:
Picture of the original:
14 Cayenne Turbo S
06 Cayman S
68 TVR Tuscan LWB
Old 02-02-2024, 09:34 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #883 (permalink)
Sunday Update
Small update, control arms and crossmember cleaned/blasted/painted:
Before:
After:
14 Cayenne Turbo S
06 Cayman S
68 TVR Tuscan LWB
Old 02-04-2024, 05:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #884 (permalink)
Rear Parking Brake
Started working on getting the rear parking brake sorted out. From what we can tell the RSs with lug nuts used the typical brake shoe 911 rear emergency brake while the cars with center locks use the "clothes pin" style rear e brake. This build will be using the Zuffenhaus 930 style calipers that conveniently are premade to mount the clothes pin style setup. AASE currently offers a kit that is made to work with the Zuffenhaus made caliper.
AASE kit to be installed:
14 Cayenne Turbo S
06 Cayman S
68 TVR Tuscan LWB
Old 02-06-2024, 05:14 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #885 (permalink)
Gus Berges's Avatar
Is there a target date for completion? Just curious...
Will this be a static display, Pebble Beach Concours, cars & coffee, or tracked? Asking simply because of the level of details that are going into this car and the time it has taken so far to complete such details.
Now: 2013 Cayenne GTS
Ex: 1999 C2, 2004 Cayenne Turbo, 2002 C4S, 1999 BMW M Z3 Coupe, 2013 Audi RS5
Old 02-06-2024, 05:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #886 (permalink)
Hi Gus,
Great question, nothing specific with regard to a completion date, my hope is before the end of the year including the sorting that will be required to get this running well. It will be interesting to see if its possible to make the slide valves perform well on the street.
Plan is to use the car for PCA events/C&C/and 7 tenths DE driving. I live near tail of the dragon, definitely planning on some mountain weekend trips!
14 Cayenne Turbo S
06 Cayman S
68 TVR Tuscan LWB
Old 02-06-2024, 07:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #887 (permalink)
Pics of how it should mount from the AASE website:
14 Cayenne Turbo S
06 Cayman S
68 TVR Tuscan LWB
Old 02-06-2024, 03:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #888 (permalink)
Mounting bracket included with the kit:
Mounting point on the caliper for the bracket:
14 Cayenne Turbo S
06 Cayman S
68 TVR Tuscan LWB
Old 02-07-2024, 05:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #889 (permalink)
When we went to install the mounting bracket that came with the kit it was discovered that it wasn't wide enough for our aftermarket rotor which is 32mm thick. The kit is made for the stock 930 rotor which is 25mm or less. Ended up having to fabricate a wider bracket to fit our rotor:
14 Cayenne Turbo S
06 Cayman S
68 TVR Tuscan LWB
Old 02-07-2024, 05:35 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #890 (permalink)
911 tweaks's Avatar
Nice…!
That’s one meaty rotor……..!!
I live for 911 tweaks...
Old 02-07-2024, 07:53 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #891 (permalink)
scootermcrad's Avatar
@ktr6 Oh man! Great to see an update! Glad to hear there is momentum, as well.
Has this car been moved from North Carolina?? I see your location has changed to Knoxville.
Old 02-12-2024, 08:20 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #892 (permalink)
Bill Verburg's Avatar
hmm
930 used 304x32mm front and 309x28 rear rotors, only the '74-77 930 used the 911 size rotors 20mm rotors
afaik the same sizes as the '73/74 RSR
here's a very original '74 934
front
rear, not sure if there is a parking brake
Bill Verburg
Old 02-12-2024, 01:40 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #893 (permalink)
Steering Rack
Small update, steering rack and crossmember are cleaned up and ready to install!
14 Cayenne Turbo S
06 Cayman S
68 TVR Tuscan LWB
Old 03-14-2024, 04:57 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #894 (permalink)
Clutch Install
The clutch still needed to be installed so got the car on the lift and dropped the engine:
Parts ready for install:
Flywheel installed and marked:
14 Cayenne Turbo S
06 Cayman S
68 TVR Tuscan LWB
Old 03-30-2024, 07:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #895 (permalink)
Clutch and PP finished up:
14 Cayenne Turbo S
06 Cayman S
68 TVR Tuscan LWB
Old 03-30-2024, 07:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #896 (permalink)
Caliper and parking brake parts ready for assembly:
Both sides installed:
Pic from below so you can see how the pad fits etc:
14 Cayenne Turbo S
06 Cayman S
68 TVR Tuscan LWB
Old 03-31-2024, 04:51 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #897 (permalink)
lateapex911's Avatar
Those calipers are so cool. The parking brake though...pretty sketch LOL. Not Porsches best, but I get the situation and the era and the goal....
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 03-31-2024, 02:40 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #898 (permalink)
Hotrod Construction
This car is going to be fantastic! Great pics with descriptions! lol
Old 04-03-2024, 05:42 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #899 (permalink)
Parking brake handle restoration
14 Cayenne Turbo S
06 Cayman S
68 TVR Tuscan LWB
Old 06-15-2024, 10:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #900 (permalink)
