I guess I should throw my results out there too. 3.2, stock with SSI headers and GHL 2 in 1 out, 239Hp at the crank (engine dyno). We also tested a M&K and produced 4 hp less. The engine is also running new KB P&Cs which I have heard produce slightly less hp than Mahles but I bought them cheap on Ebay.
Old 12-23-2007, 09:29 PM
Large Registered Member
PatrickB's Avatar
Are you running a SW Chip Bob?
I guess I should throw out that my original never opened engine has 162k on the clock...
'85 Carrera Coupe, Marble Grey #118 JP/R6
'93 Lexus SC400, '00 Ford F-150
'70 911T- 2.7 (SOLD)
Old 12-23-2007, 10:05 PM
Steve W's Avatar
Hey, thanks for the kudos guys! Those OBX headers look pretty well made. Patrick sent a bunch of pics of them and the miters where the primaries join are pretty good. It's basically an all stainless version of the European George headers. The O.D is 1 11/16", which measures 1 5/8" i.d.
Afterwards, I only drove the car two blocks up and back, and was very surprised at the top end power - it really rips and has fantastic throttle response. It's a lot faster than the dyno shows - I think this dyno had been reading low. Don't be surprised when Patrick pulls you 3 car lengths on the straightaways at the next track outing!
Old 12-24-2007, 02:17 PM
PatrickB's Avatar
Originally Posted by Jeff Alton View Post
Patrick, what size is the OD on the primaries on those headers?
Cheers
Here are some header pics Jeff~
at the collector, 1-7/8"
at the head, 1-5/8"
Jeff Alton's Avatar
Thanks! Good pics.
How close are they to the rear shocks? I had a set of similar ones that I could not use because they rubbed on my coil over.....
Cheers
www.turn3autosport.com
Old 12-24-2007, 05:24 PM
PatrickB's Avatar
Thanks! Good pics.
Cheers
Tough to tell from the pictures posted... Plus, I guess it would make more sense to see it when the car is on the ground... When on the lift, it looked like there was about an inch or more clearance. I guess the coil overs take up a bit more room. I'll see if I can get my large arm under the car with a camera tomorrow... Sounds like a good enough excuse to escape from the dinner table tomorrow!
Old 12-24-2007, 07:52 PM
Jeff Alton's Avatar
Cheers
Old 12-24-2007, 08:33 PM
450knotOffice's Avatar
I am impressed, Patrick. Looks like I might have to add headers and your muffler to my list of mods.
Old 12-24-2007, 09:34 PM
PatrickB's Avatar
It's the cheaper way to go... $350 for headers, and $180 for the muffler!
Old 12-24-2007, 09:39 PM
Jeff Alton's Avatar
Which dynomax is that?
I am hoping to pick up a set of these headers, if they clear my coilovers. I want to dyno them against my QSC ones that I have now. I also want to bolt up a set of Coast Fab mufflers to them.
Cheers
Old 12-24-2007, 09:53 PM
PatrickB's Avatar
Dynomax 17276. Ultra Flow Stainless. 2 in / 2 out. With 2-1/2" inlets/outlets.
Very light too. I think it was under 16lbs.
I can't wait to see your dyno results! I haven't been following the progress of your rebuild Jeff...
Stock, mild, or wild on the rebuild specs???
Old 12-24-2007, 09:57 PM
Jeff Alton's Avatar
Wild......
3.4 twin plug
10.5 CR
Mod "S" cams
Jenvey ITB's
Custom ported Jenvey manifolds
Race valve springs
Ti retainers
Headers
Boatailed case
ARP head studs
ARP rod bolts
Balanced pistons
Balanced rods
Microtech EFI with crank trigger and 6 dual tower MSD coils......
yada yada yada.....
The exhaust has been a challenge for me. Started with B&B/M&K too loud..... Bought Georges headers, didn't fit, now bought QSC ones and have another M&K on the way. Would also like to try these headers with Coast mufflers too!
In mid january it goes back to the dyno to for final tunning now that it is broken in.
STEVE WONG CONTENT..... I have bought and installed a few of Steve's chips over the last few years, every one has been more than pleased. Steve was kind enough to educate me on some advance curves for my motor and even sent me tons of specs and info to help get me started on the initial tune of the motor!! Great guy!
Cheers
Old 12-24-2007, 10:11 PM
PatrickB's Avatar
Wild......
3.4 twin plug
10.5 CR
Mod "S" cams
Jenvey ITB's
Race valve springs
Ti retainers
Headers
Boatailed case
ARP head studs
ARP rod bolts
Balanced pistons
Balanced rods
yada yada yada.....
Cheers
Good God... My dream motor Jeff!
So I'm guessing the twin plug set up allows you to run the higher compression on 91 octane fuel?
I was seeking a light weight muffler that wasn't too loud, but also had good flow characteristics. I think I reached a happy medium with this muffler! Much quieter AND better flowing than Flowmaster. I've heard M&K's with stock exhaust manifold & a cat bypass in person, and my set up with headers & Dynomax is quieter.
Old 12-24-2007, 10:22 PM
Jeff Alton's Avatar
Clearly from the power you are making, that muffler flows well!!
I am running it now on 94 octane which is readily available here locally. The ECU allows me to store 4 seperate programs which I will tune for different octane. When I venture into WA state for trackdays pump fuel is 91 or 92 at best but race fuel is available at the track, not sure what to expect at Portland, Thunderhill and Laguna when I get down there this summer.
10.5:1 with 98mm cylinders pretty much requires twin plug and I feel okay about running the 94 in it here. At the dyno they have some high octane fuel as well, I believe 100, so we will tune it to that as well. I can always back out a few degrees of timing at the track if good fuel is not available, takes about 30 secs to make the changes.
Cheers, merry christmas!
Old 12-24-2007, 10:50 PM
PatrickB's Avatar
From a stock never opened 162k mile 3.2...
What is your hp goal out of this build?
Merry Xmas back at ya! You better hit the rack soon Jeff... That wake up for work alarm is getting closer & closer...
Old 12-24-2007, 11:12 PM
I'll race for food
gostraight's Avatar
cheatter! that's close to what the "Beast" has
Radu
'82 SC black on black "The Beauty"
3.8 RSR GT2 track/street "The Beast"
www.octanegallery.com
Old 12-25-2007, 02:59 AM
Does anyone have experience with a SW chip in a 964 with the light weight flywheel? I know that going from the dual mass to the light weight version can create stalling issues so I'd like to know if SW chips can adjust for this.
TIA,
Grady
Grady aka plain fan
66 912 - enjoying the good life
78 911 SC and 90 C2 turbo look cab - gone but not forgotten
01 996 TT -
09 Audi A4 Avant - daily driver
Old 12-25-2007, 08:27 AM
Sports Purpose 911 Driver
mjshira's Avatar
TIA,
Grady
yes, suggest you email Steve. he has done chips for a number of our 964 cars.
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 12-25-2007, 08:35 AM
Send a message via Yahoo to shoguneagle
First of all, thanks for the very informative thread on the chips, headers, and mufflers. Yes, the experience and comments on Steve Wong's chips. I also liked the "oil cooler" on I believe Patrick's car. I have a friend that runs one on his hand build '32 Ford Pickup and provides effective cooling. Patrick's number of cooling 25 degrees in hot weather is impressive (along with the frontal scoop).
I know I am going to get a Steve Wong Chip for my 1987 3.2 Carrera engine; I will run headers as described, and probably the free flowing muffler mentioned in the thread. Steve goes out of his way to answer and help fellow Pelicanites and does produce a great product.
What I am interested in is the cooler and the possibility of using it as the heating element for defrosting/heating duties. I was thinking of building a chamber around one or two of the coolers and route air to the air tubes going forward. I am thinking of using the normal air/heating source, route the oil into the the rear with air flowing over the cooler(s), and then to the normal heater/defroster ducting system.
I know it would take a long time for the system to provide heat but I am only planning on using the car on immediate to long haul trips.
I should mention the car I am building is a 914-6GT Replica of sorts. I have questions involving the oil cooling capacity for this type of cooler used in conjuction for heating/defrosting. I already have a modified engine cooler; will I have to install a front cooler? How does this affect the SW Chip performance?
I would appreciate comments involving headers, mufflers, SW Chip, Oil Cooler with heating system, etc.
I do apologize if I have "highjacked" the thread from its origination. Saw the installation of the headers, dicussion on SW Chips, and the "oil cooler" which got me to thinking about what my conversion package requirements would be.,
Thanks,
Steve Hurt
Old 12-25-2007, 08:12 PM
Jeff Alton's Avatar
I have installed only one 964 SW chip for a customer, car was tiptronic. He loved it.
Patrick, I am hoping for around 300hp at the flywheel. It feels strong enough to me the way it is now (and we are no where near done with the tuning) so the number is not all that important, the throtlle response and character of it made the money worth it.
Cheers
Old 12-26-2007, 09:33 AM
