Brad w's Avatar
CIS injectors
How do you remove the CIS injectors on a 1980 911 sc from the spyder? Correction (intake manifold) or spider for the old 928's
Brad W 1980 911 SC
1982 928 Auto
1982 928 5spd Comp PKG
2005 SLK 350 w/ AMG Pkg
2007 Hummer H3
Old 01-06-2008, 07:54 AM
Brad, I know the 550 Spyder had carbs the Boxster Spyder doesn't have CIS and the race car "Spyder" also doesn't have CIS
Are you asking about your SC? I believe they pull straight out and are held in place via an "O" ring. (If I'm wrong, someone will chime in)
Old 01-06-2008, 08:17 AM
Brad w's Avatar
I am calling the intake runners a spider. That what we call it on the old 928's
Brad W 1980 911 SC
1982 928 Auto
2007 Hummer H3
Old 01-06-2008, 09:00 AM
CIS Injector Puller Gadgets.....
Brad,
CIS injectors are sometimes very stubborn and difficult to remove. And you need good grip and leverage to pull them out. There are many kinds of tools you can employ and just use what works for you. My home-made injector pullers.
Tony
Old 01-06-2008, 09:14 AM
Somatic Negative Optimist
Gunter's Avatar
Do a search under "Injector removal" or "Intake runners"; lots of info on removing with the help of WD-40 plus 2 wrenches, prying straight up.
Been covered many times, but not under: "Spyder" or "Spider"
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 01-06-2008, 09:20 AM
Jim Williams's Avatar
My injector removal tool straight from the tool box. 12 mm crow's foot for 3/8" drive, 6" long 3/8" extension, and a 12 mm open end wrench as a spacer.
Jim
www.jimsbasementworkshop.com
(CIS Primer for the 911)
(73 911T (RS look) coupe)
(Misc. 911 Parts for Sale)
Old 01-06-2008, 10:42 AM
vash's Avatar
i have the tool similar to tony's. that L-shaped bracket. the only time i removed the injectors, on my 75 car, i used the tool. i attached a length of nylon strap to the tool, so i could use it as a wrist-strap. if i stood over the injector, i could just jerk it out. oh, wear leather gloves. none resisted very much. jim's method looks more refined, and much less of a knuckle buster. i like it!
poof! gone
Old 01-06-2008, 03:44 PM
