Throw it on the ground!
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
Ha, you noticed, those are temporary window switches. I had a car with manual cranks, then decided that i cannot live with them so i installed electric motors and ran the window switches under the dash. I'm not looking for a perfection, its a temporary but does the job.
Member 911 Anonymous
Hey Mark,
I attempted to tap my reverse light trigger (Grey/Brown Wire) in the engine bay but for some certain reason I can't get power to the camera. Tested it with a 9 volt source to make sure the camera works and got a picture on my receiver/display. Did you tap with the black or red wire from the camera and where did you ground the remaining wire? TIA, Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 07-11-2009 at 11:30 PM.. |
Hope this helps.
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 07-12-2009 at 06:29 PM.. |
Oh Hey Mark,
Thank you for the quick reply, I really apprecaite it. "always ACC on". Wow, I did not know that. Funny, I always thought once in reverse that would be the power source. Now that makes sense, because my head unit has the ability to turn on at low speeds coming to a stop. I was trying to figure out how the head unit can turn on if the reverse lead is not activated. That is why I assume you placed a manual override switch to control the power input to the camera. I will need a switch too because my camera has both infra red and exterior lights mounted around it. Thanks Brother!
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 07-12-2009 at 06:18 PM.. |
Performed a switcheroo today. Moved the Pioneer camera to the SUV and installed a new Alpine camera integrated in an Alpine frame. Much cleaner install, plus I like the the higher camera mounting position.
From this: ![]() To this: ![]()
Just my 2 cents, but I like the more sutle look of the first position.
I'm biased because mine is tucted under the tag.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
