azporsche911.com
What to use to repair CIS airbox?
What Should i use to repair a crack in my CIS airbox, Epoxy or JB weld? I have JB weld handy and i have seen it done but what is recommended?
-Jeff
Jeff Hoffman (Son) Tom Hoffman (Father) 79 911sc ROW guards red coupe father son project. |
Jeff,
While I do not know the answer to your question, I will offer to you the fact that JB Weld is epoxy with a filler to help make the joints stronger.
I would use the JB Weld. Let us know how it works.
you need something like the original glue which melted the plastic at the joint and then set up as a virtually "welded" joint. JB etc won't do it. it will just lay on the surface. so far i haven't found that elusive glue the factory used. acetone melts regular plastic, ABS plumbing cement melts/bonds with plastic plumbing pipe, but airbox plastic is unfazed by them.
Bland
The airbox is rotomolded polyethylene or polypropylene - both are olefinic thermoplastics. The only glue that will stick to olefinic plastics is 3M DP8005 or Loctite makes a similar product (3030 I think). You can get this stuff from an industrial supply store such as Acklands or Century Sales - not sure who would supply in the US.
You can use this to glue a polyethelene patch over a hole or a crack. Milk jug material though ugly is a good candidate but anything you can find with the mombius loop and HDPE or PP below it will be fine. ON my 77, the airbox has been repaired with black tape which has held fine since before I bought the car 4 years ago. Otherwise you can weld the air box up which will also be ugly.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
Designer King
Unclebilly,
Did you use hockey stick tape? (Canada, eh!)
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Dang unclebilly, it sounds like you and my youngest Son, would get along just great. He got his degree in polymer science.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
Dog-faced pony soldier
I'd replace the airbox, but that's just me.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
I have an air box with a pop off valve available. $40 plus shipping if you want it.
Matt West 1980 911 SC |
Has anyone tried chyochrylate adhesive not exactly sure of the name but they call it CA glue. Its commonly used by hobbyists and found at hobby stores. Some plastics it has no effect but for the most part it can glue pretty much anything extremely well.
82 SC , 72 914 |
That is super glue, I am looking at a tube right now. One of its first uses was in the funeral industry, long before anyone ever heard of "super glue" back then, in the very early 70's, it was very expensive, about $12.00 for a 10gram tube. The main reason the funeral homes used it was because it bonds skin extremely well, and lacerations on a face or hand could be closed up, without unsightly sutures showing.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... Last edited by 3.2 CAB; 01-08-2008 at 11:51 PM.. |
Make My Day
"I'd replace the airbox, but that's just me."
Ditto
74 911S Targa ROW Building Designer/Business Owner |
azporsche911.com
I have already went ahead and used JB weld, turned out good. I sanded and cleaned the surface so it should be strong. I have a the large port airbox and figure it will be a slight challenge finding another one. If this box fails in the future, im just gunna go ahead and buy PMO's. I always dreamed of doing that anyway.
-Jeff
Bland
![]() I did have some black hockey tape on there for a while but went back to the electrician's tape. I will be putting webers on that car in the not too distant future
I'd think (aside from sourcing a cheaper used part) replacement is often too expensive to be easily justified - even for the people who seem to have waay too much money to throw at their Porsches ![]() Aside from that, I'm always interested in quality, low-buck solutions too. Last edited by stevemfr; 01-10-2008 at 03:25 AM.. |
Do we know what the box is made of?
Air box glue loctite plastics bonding system
Old thread but found this Loctite plastics bonding system and wanted to know if anyone has used it to repair an air box. A major backfire split my air box and am trying to repair.
I would try hardware store variety RTV sealer. All it needs to do is seal a vacuum and if it blows up again, there is nothing strong enough to prevent it from going to pieces anyway. Not even a pop off valve.
Cheers, Joe |
I have used that Loctite plastic bond with good success on smaller items (center console plastic). However, something larger with potential for gaps, I would use a two part epoxy for plastics. I believe Loctite has such a product that I've used successfully as we'll.
