Originally Posted by MrPerkles View Post
Nice car ive been following this thread,please tell me you are putting longer studs on the wheels ?
Their is already in place longer studs to account for the 1" wheel spacers. There is plenty of thread engagement in the nuts - see the pic below with spacers in place. The blue nuts I am using, while they have an open end, are the same length as OEM nuts ( actually about 3mm longer ), so hence you don't see thread coming through the end..
Earlysport
_____________________________________
69 911E, 69 911E RS Rep 3.0L Hotrod, 77 930
IROC REP 3.6L SOLD, 968CS SOLD, 987 Boxster S SOLD
Old 06-17-2009, 08:57 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #101 (permalink)
Originally Posted by Bill Verburg View Post
Love the painted seat backs! What sidemounts are you using?
I'm pretty sure they're a Sparco side mount. I'm running the outer ones 'flipped' so the seats are as far toward the centre of the car as possible ( maintaining clearance between the two seats ). A bit less pedal offset that way :-) I've had the side mounts and matching sliders for a while - with the outside mounts flipped they line up with the factory seat mounts and only required drilling some new holes to meet up with the OEM captive nuts.
Earlysport
Old 06-17-2009, 09:03 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #102 (permalink)
where's my receipt?!
haha. nice work craig.
ray
Old 06-17-2009, 09:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #103 (permalink)
Bill Verburg's Avatar
Yes, I noticed the flipped sill side mount, the only others I've seen like that are the original Cup seats. I guess that the PP's must be narrow enough to do that
Bill Verburg
Old 06-18-2009, 06:55 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #104 (permalink)
I have a pair of Momo '1000lakes' seats in an RS Replica that are also mounted the same way, although I needed a welded frame to fit them (see pic below) The outer mounts are flipped to get the seats as close to the centre as possible. The 1000 lakes aren't that narrow, I thik it's more a function of the straight up and down side mounts. The standard Recaro mounts have a bend in them, which I think precludes flipping them to offset the seat.
In both the RS Replica and this IROC project the seats are close to touching in the centre.
Earlysport
Old 06-18-2009, 05:07 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #105 (permalink)
I went through this this past winter, I purchased sidemounts from BK, Recaro(2 different kinds) and Speedware the only current sidemounts w/ a bend are from Speedware.
Bill Verburg
Old 06-19-2009, 05:13 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #106 (permalink)
Ambitious Outsider
sabeo.m's Avatar
Subscribed...
Great project!
1988 3.2 Cab
2005 997.1 C2S
Old 06-19-2009, 08:52 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #107 (permalink)
A quick update;
Door panels are now in place. Eventually the pull straps will be swapped for mexico blue versions. If you look carefully you'll note the pull straps are further back than normal - long story, but basically these are early car versions that have been modified, and hence the bellcrank position was moved rearward to suit on the door skin. Door tops have been trimmed in suede to match the dash. Door lock buttons have been deleted.
Outer door handles are being re-fitted too. This is the passenger one - we don't need no steenkin' key locks!
And just as a sneak preview, here's the car sitting on it's wheels after a 30 minute shakedown drive..
Earlysport
Old 06-22-2009, 05:21 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #108 (permalink)
Ambitious Outsider
sabeo.m's Avatar
Thumbs up
Right on! Super wicked!!
1988 3.2 Cab
2005 997.1 C2S
Old 06-22-2009, 10:10 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #109 (permalink)
A final post showing some finishing details.
An oil breather catch can is important for track use. This is an off the shelf ricer product, but fitted my desired mounting location well.
A lightweight sealed battery designed for a Harley motorcycle is used. A fabricated aluminium mount keeps it secure. A two pole battery isolator switch is on the ground. I may swap this for a four pole at a later date.
The suede headliner was in place some time ago, but this is a better shot. It also shows the underside of the fibreglass sunroof replacement panel, trimmed underneath in lightweight carpet. My sunroof insert weighs 1.5lbs.. Eventually I want to do a carbon version.
The final touch for the exterior is the custom carbon reflector replacement. A sticker was used as a mask, and the panel painted in mexico blue. Removal of the sticker and then clear coat results in the raw carbon showing through the Porsche script.
Finally for this post here's a shot of the engine bay complete.
Earlysport
Old 07-25-2009, 04:34 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #110 (permalink)
Finished!
Finally the project has come to and end, and stage two of the fun begins - driving ;-)
There is always more to do, and continuing development, but for now the IROC is going to see some track time on Aussie circuits. It debuted two weeks ago at Wakefield Park in NSW, and despite some pretty severe weight jacking as I had no time to corner weight it, the car was a blast to drive and quite fast. Of 50 odd cars entered in the Porsche Club NSW super sprint, I ended up 12th outright and 2nd in class - not bad for a shake down run. The car is very predictable to drive and responsive. All the makings for lots of fun!
Here's some shots I snapped today after a quick wash. I still haven't colour sanded the paint and buffed - that'll come prior to a concours event in October. You'll also note no exhaust tip - I'm fabricating a new one.
Earlysport
Old 07-25-2009, 04:44 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #111 (permalink)
Metal Guru
911nut's Avatar
Congratulations. That is a very cool project!
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 07-25-2009, 04:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #112 (permalink)
Earlysport
Old 07-25-2009, 04:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #113 (permalink)
Max Sluiter
Flieger's Avatar
Bonza!
Old 07-25-2009, 01:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #114 (permalink)
Eye of the Toiger
matty74's Avatar
Hey Graig,
where did you get those rims?? Tempted to get the same set of shoes for my machine.
Matt
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 07-25-2009, 03:33 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #115 (permalink)
cameron.arnott's Avatar
Really nice result Craig, well done!
'74 RS 3.0 Replica
Porsche 968 Clubsport SOLD
'70 911E Bahia Red SOLD
'71 911 S/T Replica 2.3 Twin plug BEAST SOLD
Old 07-25-2009, 11:56 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #116 (permalink)
MrPerkles's Avatar
Send a message via MSN to MrPerkles
Thumbs up
money shot and it looks great nice job well done
www.facebook.com/pages/Bournville-Frameworks
Old 07-26-2009, 01:49 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #117 (permalink)
tb912's Avatar
Very tasteful. I dig it.
Old 07-26-2009, 01:52 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #118 (permalink)
love it
Old 07-26-2009, 05:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #119 (permalink)
otto in norway's Avatar
Wicked look!
Very smooth..! I'm Impressed!
Old 07-26-2009, 10:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #120 (permalink)
