1971 911T's Avatar
rear end whomp whomp whomp
taking advantage of the mild and sort of dry weather been driving the car.
i'm only on about 500 miles since i got the car, so it's still 'shaking down cruise' days.
this morning the rear end driver-side started having a rotational whack-whack sound, like a flat tyre, but harder, almost a 'thump'. disappeared when accelerating, resumed when cruising or decellerating.
it's too dark to check it out. what could this be? the car handled normally...
Old 01-09-2008, 02:41 AM
old man neri's Avatar
If the car was sitting for a while it could have just been a flat spot. Why only in that tire? I don't know, maybe when it was stored that tire lost a bit more air than the rest.
It could also be a suspension problem. I think if you search 'cupping' it might give some insight.
Cheers!
Old 01-09-2008, 03:11 AM
Kantry Member
oldE's Avatar
While you're under there, check for loose/worn CV joints.
Badly torn CV boots might do it too and if they're that bad you have some R&R to do on the joints themselves.
Good luck.
Les
Best
Les
Old 01-09-2008, 03:23 AM
Bland
unclebilly's Avatar
I second the CV joints...
Old 01-09-2008, 07:44 AM
