86ragtop
Guest
Posts: n/a
Question Warren and all good wrenches Please help!
Hi warren, and all, please can someone help identify this small pin (by quarter)from my tranny in case driving without it causes a major !
Thanks Guys
Old 03-26-2001, 01:50 PM
andyjboy
Guest
Posts: n/a
Post
ragtop - is it a solid pin or is it a roll-pin (hollow with a longitudinal 'split')?
Andy (UK)
'69 911E
Old 03-26-2001, 02:20 PM
86ragtop
Guest
Posts: n/a
Post
Andy,
It is a solid pin,seems highly polished!.
no scratch marks or signs of impact/breakage.
hope this helps
Ben
Old 03-26-2001, 02:27 PM
john walker's workshop
Guest
Posts: n/a
Post
if it's solid i would imagine it's from one of the needle bearing cages the gears roll on.
[This message has been edited by john walker's workshop (edited 03-26-2001).]
Old 03-26-2001, 02:52 PM
Huey581
Guest
Posts: n/a
Post
Hey 86!
Give me a fax number and I will fax the parts diagram from my factory manual. There is a "Spiral Pin" that looks like yours on the inside of the tranny that goes in the "Castle Nut" that screws into the "Reverse Gear Set". Also there is a second pin that goes inside the tranny for 5th gear. At least I can read the pictures!
Huey581
86 911 Cab
Old 03-26-2001, 02:55 PM
86ragtop
Guest
Posts: n/a
Post
Thanks Huey and all,
have e-mailed my fax no. to you direct.
rgds Ben
Old 03-26-2001, 03:05 PM
Early_S_Man
Guest
Posts: n/a
Post
Ben,
From the equal-length discoloration at both ends ... that is, with 100% certainty, a needle-bearing roller!
Warren Hall
1973 911S Targa
Old 03-26-2001, 03:38 PM
feelyx
Guest
Posts: n/a
Post
That looks like a needle bearing from the input shaft. 2 different sets there, and also on the pinion shaft gear cluster. I hope it was missed in the tranny rebuild (stuck to some goo) and you just flushed it out.
good luck
Tim in Sac
Old 03-26-2001, 04:09 PM
86ragtop
Guest
Posts: n/a
Post
Okay warren a 'needle bearing roller' you say.
Excuse my lack of knowledge, but is it important?.
As you may remember, this is a 4 month old rebuild by Vertex (6 month warrantee)
Does it warrant another rebuild?
Is it that serious or what?
You were right about a small amount of discolouration about 1mm at either end!.
Should I drive it?
Should I even worry about it?
Please advise (I trust you guys more than the mechanics who profit by my lack of knowledge.)
thanks Ben
PS Huey recieved the fax thanks!
[This message has been edited by 86ragtop (edited 03-26-2001).]
Old 03-26-2001, 05:18 PM
Early_S_Man
Guest
Posts: n/a
Ben,
The significance of the discoloration is that it is a 'used' bearing part, and was probably inadvertently left inside during the rebuild, but the magnet did its' job ... and kept it out of harm's way! I believe that the roller is from a 5th gear roller cage, as that bearing has to be removed by hand during the disassembly, and replaced during final assembly steps. And, no, I don't think you have anything to worry about! I believe you can drive your car without worry!
You may want to discuss this matter with Vertex, to see what they have to say. I'm sure they can show you a 5th gear roller cage for comparison with the roller you found, and verification that it is the proper length for that bearing.
Warren Hall
1973 911S Targa
Old 03-26-2001, 06:34 PM
86ragtop
Guest
Posts: n/a
Wink
Thanks Warren,
I will sleep soundly tonite!
I will show it to Vertex as suggested and hear their comments, who knows what they may offer ('zip' probabley)
Anyway thanks all others for helping aswell!
regards ben
Old 03-26-2001, 07:00 PM
