126coupe's Avatar
Assembling a 901 Box Question
The thin paper gaskets on either side of the intermediate plate, do you install dry?
The last time I used gasket cinch which was not a good idea. The gasket cinch actually ruined the gasket which in turn caused a leak.
I realize that different thickness' of gasket is part of the measurement.
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 01-19-2008, 11:12 AM
abit off center
cgarr's Avatar
yea those are thin and rip easy, Dry is good.
______________________
Craig
G2Performance
Old 01-19-2008, 11:38 AM
Grady Clay's Avatar
I agree - dry. The key is to make sure there aren't anydamage to the surfaces. Another is to inspect around the studs where the are in the main casting. Occasionally there is old sealant there that can interfere.
Only the gaskets between the intermediate plate and the main casting are shims. The gasket between the intermediate plate and the nose piece is just a gasket.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 01-19-2008, 12:20 PM
i like a fine coating of K+W coppercoat spray, then let it dry real well before using. the joint surfaces probably are not perfectly flat like they were when new. thicker sealants will squeeze out and take the gasket with it.
206 637 4071
Old 01-19-2008, 01:08 PM
126coupe's Avatar
Best,
Grady
I removed the studs on the housing and was planning on getting a piece of glass and some superfine sandpaper and "fine tuning" the surfaces.
28' Pace Trailer
Old 01-19-2008, 01:13 PM
