Warm up running problem
Hello,
We just bought a 72 Porsche 911 that looks like a 1990 but has a 2.7 CIS engine that appears to be from a 1976.
It starts right up but dies off again and again until the engine is warmed up. Once it's warmed up, it runs great.
Any suggestions as to where to start looking for this problem?
Old 01-29-2008, 08:12 AM
Leaking fuel pump check valve, a warm up regulator that's out of adjustment, a cracked air box, vacuum leaks?
Old 01-29-2008, 09:05 AM
Designer King
Paulporsche's Avatar
You should search the items stlrj mentions. The WUR, AAR and vacuum leaks are probably the most likely items. does your airbox have a popoff valve?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 01-29-2008, 09:49 AM
