Livin' the Dream
What makes a new Porsche's A/C work better than a 911's
Can someone tell me what makes modern Porsches (Boxster, Cayman, 996 etc) A/C's work so much better than our older 911s? More condensers? condenser location?
'84 911 Carrera |
RETIRED
Specifically better compressors, condensors and hoses that keep the gas from leaking.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Designer King
Does anyone know if water vs air cooling the engine helps? Do the newer engines run cooler?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Michael Delaney wanna-be
I would say technology and engineering. In the new models it was engineered in. In the older ones, it's like the finished the car and then said "Wait...we need A/C also".
88 Carrera Cab C.R.A.P. Gruppe Member #7 |
Correct....no coolant runs through the A/C system. Paulporsche....the new ones have to run water cooling because air can only cool the engine so much. With all the HP gains as of late, they had to switch to water cooled.
Metal Guru
Larger condensers and evaporators are what makes modern Porsche A/C better than the pre-90 911.
The 911 chassis architecture was designed in 1963 when only us Americans were interested in A/C so there were no provisions for a packaging a proper sized condenser and evaporator. Later a system was shoehorned into the 911 with condensers located in two spots that don't receive good airflow and the evaporator hidden in the smugglers box that was never intended to hold anything other than the optional gas heater. All these problems were solved in the 964/965 series of 911 but it took completely new chassis architecture to package the right sized components. On a 90 degree day here in Michigan (typically 80% humidity) my A/C gets so cold I have to turn it way down if it runs longer than 20 minutes.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
The good news it the aftermarket!
My 85 Carrera has COLD air now. All it took was some parts from Griffiths and a couple of weekends of work. For many years War Bonnet Region PCA held the War Bonnet Tech. We had speakers from the factory every year. I don't remember the exact year but It was probably the early 80s when Helmut Bott spoke to our group. I think it was Bott that decided to drive Rt 66 west from Oklahoma City in a Porsche provided by PCNA. When he returned to Germany he had two of the top A/C engineers fly to America to take the same "vacation" on Rt-66. When they returned they reported to him and said "the A/C in the 911 sucks" or something like that in German. One of the engineers that came to discuss the new 993 told us the story. He mentioned the 993 would have A/C that works. That was the year they brought the entire rear suspension of a 993 for display at Tech and just left it with us. I still have a 993 wheel hub and crossmember hanging on the wall in my garage.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! Last edited by GH85Carrera; 02-03-2008 at 07:56 PM.. |
I can only imagine how much better your car cools now! One day...
Mike '84 Grand Prix White RoW Carrera |
Mostly condenser area.
R12 actually cools better than R134a, so that's not a factor. |
Virginia Rocks!
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
Detached Member
Sticking one condensor above the engine has a lot to do with it on the older ones.
Hugh |
