deshetlr's Avatar
Engine Pad - Installed!
The winter list just got one project shorter. I installed a new OEM light weight pad WITHOUT dropping or partial dropping the engine.
Here's the engine bay without the pad.
I did a lot of scrapping and scrubbing. Next is the pad. Note the pad must be installed with the skin toward the engine since there is a hole for a wire to come through on the left side. I did not know how to unplug the wire so a quick snip with the scissors and the problem was solved.
Next on the list was dismantling. Air cleaner, cruise module, heater fan and ductwork all came off.
I then dry fit the pad. Not an easy process and certainly would have been difficult with glue applied. Once in place at the back the top of the pad was laid on the engine. I bet I test fit and adjusted a half a dozen times. Once I was satisfied I applied 3M super adhesive and 3M spray adhesive on the pad. I was only able to apply from where the pad turns horizontal to the exposed edge. It is well glewed. With all the tubes, wires, etc. at the bottom I can't see the lower part of the pad moving. So here it is. Looks great. One down. Many more to go.
Scott
'86 911 Carrera Coupe, PCA, PBC
Old 02-10-2008, 08:56 PM
Looks pretty good. Did you notice any reduction in sound?
Marv Evans
'69 911E
Old 02-10-2008, 09:37 PM
gungadin's Avatar
+1
sub'd
'76 911S w/ '79 3.0 SC engine. Irish Green
Old 02-11-2008, 12:58 AM
deshetlr's Avatar
Still snow on the ground. Hopefully I'll get out in a couple of weeks to check sound.
Scott
Old 02-11-2008, 05:16 AM
Looks nice!
Did you use the pad Pelican sells?
I need to put this on my list of things to do also.
Scott
Old 02-11-2008, 05:40 AM
deshetlr's Avatar
Yes. It is the OEM light weight pad from Pelican.
Scott
Old 02-11-2008, 06:18 AM
1984-911 M491
Trog's Avatar
I recently changed my pad as well... a couple of suggestions:
1- Cover your engine with an old blanket when scraping off the old mat and residual glue.. the stuff gets everywhere.
2- Cover your engine with a sheet of plastic if you're using spray adhesive. Residual adhesive may land on engine components acting like a magnet for dust, and dirt.
An ounce of prevention....
1984-911 TLC......SOLD
Old 02-12-2008, 10:28 AM
rfloz's Avatar
1- Cover your engine with an old blanket when scraping off the old mat and residual glue.. the stuff gets everywhere.....
What would work to remove the old glue and not damage the underlying paint? I am thinking of just leaving the pad out (auto-cross/track oriented car) but the glue residue is really ugly.
Bob F.
1984 Carrera Factory Turbo-Look
Old 02-12-2008, 11:28 AM
1984-911 M491
Trog's Avatar
Believe it or not, but I made great progress with a flat piece of wood (like a shim) and my thumb nail. Took about 1-hour to scrape off the bulk of the residual glue and foam.
Old 02-12-2008, 12:20 PM
deshetlr's Avatar
Get it off soon after removing the pad. I did not and the residue is as hard as a rock. I had most of it already scrapped off enough for a new pad. Removing enough to look nice exposed would have been a PITA.
Scott
Old 02-12-2008, 05:24 PM
AutoBahned
RWebb's Avatar
you can get door shims at most hardware or bldg. supply stores - when one breaks just reach into the pack for another
Old 02-12-2008, 05:28 PM
rfloz's Avatar
Unfortunately, the pad was off when I bought the car and the glue is indeed as hard as a rock.
I was afraid you might say something like that. And I just had my nails done.
Bob F.
Old 02-13-2008, 08:42 AM
KTL KTL is offline
Schleprock
KTL's Avatar
A good glue remover is this stuff
Is Noise Bearable? Sound deadening Removal
I don't know anywhere to get it on line. I've done a Google search numerous times and it appears you have to contact Ricmar directly via phone- no online store that I can locate!!!
Point being, a good biodegradable engine degreaser works well in this instance. It's worth a try to do a test with a similar product like the Ricmar stuff. Scraping off old adhesive is teh suck. Anything that makes a tedious project like this easier, i'm all for it.
Kevin L
'86 Carrera "Larry"
Old 02-13-2008, 09:26 AM
rfloz's Avatar
Thanks. I'll try to find some or a reasonable substitute.
I am really tired of a firewall that resembles Chewbacca with a bad case of mange. It's even worse than the first photo in the thread (no offense) and the car is Grand Prix White so it's hard to overlook.
Bob F.
Old 02-13-2008, 12:51 PM
deshetlr's Avatar
Bob
Thats the primary reason I put a new pad in.
Scott
Old 02-15-2008, 04:26 PM
rfloz's Avatar
Bob
But, but, it weighs a whole pound! Weight that is high and to the rear - finest kind to remove.
If I can't get it clean, I may put it in myself. Ugly vs. 1# weight loss. That is a tough one.
Bob F.
Old 02-15-2008, 04:41 PM
I wonder if I should stop posting pics of my ugly old engine bay with dried glue and clumps of old foam on the fire wall?
Old 02-15-2008, 05:02 PM
AutoBahned
RWebb's Avatar
closer to 1/2 lb.
stock items:
4.7 old style engine firewall sound pad
0.7 new style engine firewall sound pad
4 lb. wt savings new vs. old - Chuck Miller; Esses 15(1): 5
The wt. savings of 1 lb. is inconsequential unless you are in one hell of a race class....
Old 02-16-2008, 12:11 PM
Great work deshetlr. Let's us know it can be done!! I'm in the same boat, man does it dress up the engine bay. One question... did I miss something? You removed the above yet I think you posted two of the same pictures, everything intact. If I'm correct do you have a pic with the items removed?
O2 In Sully We Believe
Old 02-16-2008, 03:29 PM
oh... actually the pics are both of the dismantled engine bay?
Old 02-16-2008, 03:31 PM
