Anarchist Extremist
964 cam timing please
Any one have the timing specs for 964? I need em, please and thank you.
doing a 964 cam upgrade on my SC, heads are going on this weekend cam timing next weekend...
Chris
80 SC Coupe
00 Tundra (Tow Rig)
00 Audi A6 Avant (wifes rig)
03 Wife ('71 typ Spezial)
05 Kid (MENSA prototype)
Old 02-23-2008, 08:15 PM
Go here.
http://www.drcamshafts.com/
Looks like 1.26 MM for 964 grind. Thats what I set mine to per John Dougherty who did my regrind.
Kevin
'79 Coupe
Old 02-23-2008, 09:02 PM
Set mine to 1.26 also!
Old 02-24-2008, 05:40 AM
Somatic Negative Optimist
Gunter's Avatar
Chris
What year engine?
CR?
Are you keeping CIS?
For my SS 3.2 conversion with CIS, JW recommended 1.4 for the 964 cams which worked really well.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 02-24-2008, 09:02 AM
Anarchist Extremist
1980 US Spec Keeping CIS. cant really afford any other Upgrades unless there are some easy/cheap ones after this.
also do you or anyone else sugges I use fresh rockers? these are new cams from Dougherty.
thnaks
Chris
80 SC Coupe
00 Tundra (Tow Rig)
Old 02-24-2008, 09:36 AM
Gunter's Avatar
Rockers can be refurbished; I think Camgrinder does this. Send him an E-mail.
It may involve new bushings and a polish of the mating surfaces.
Depending on wear, you may be able to re-use the rocker shafts; they wear on one side only, look for the marks.
I turned mine 180 deg to get a new wear-surface.
How many miles on the engine?
Make sure that the shafts are centered meaning: equal amount into the respective sides and torqued at 13-15 ft-lbs.
Go around 3x for the cam timing:
Old 02-24-2008, 10:10 AM
efhughes3's Avatar
Yes, use refurbed rockers, John does this very well-priced, IMO.
Why not just ask John what he has for the timing??
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 02-24-2008, 12:36 PM
Gunter's Avatar
When you check out John's website, you'll notice that he wants additional info before suggesting a final overlap.
1.26 mm 964 profile would be for a 3.6 liter but he may suggest something slightly different when using a 964-grind for a 3.0 with CIS.
Also, he lists the overlap for SC's as 1.4 - 1.7 mm but the earlier '78-'79 (930/04) have an overlap of 0.9 - 1.1 mm.
I am sure he knows this.
Read his info about refurbishing rockers; good stuff!
Send him all required info and then go with his recommendation re: overlap and let us know what he says.
One more thing:
Do not feed new chains onto old chain sprockets (The ones on the I-shaft)
Go here:
New chains without new sprockets? Read this!
Either use new chain sprockets with new chains or re-use the old ones together.
Have fun.
Old 02-25-2008, 09:01 AM
Anarchist Extremist
I emailed JD and no response. anyone know any better way to get a hold of him?
thanks
Chris
80 SC Coupe
00 Tundra (Tow Rig)
Old 03-01-2008, 06:38 PM
