I have an early 2.4T with Webers and a little hotter cam and strongly
considering getting rid of my stock heat exchangers and installing Headers. Im wondering if this is a good upgrade to do for performance and longevity. Is it also better/needed to install the Heat Wrap around the headers? Which are recommended for my config and which ones should I stay away from?
71 Targa 2.4 WEBERS 915 box Drivetrain - http://forums.pelicanparts.com/porsche-911-technical-forum/410787-drivetrain-project-complete-3yrs-pics.html Interior - http://forums.pelicanparts.com/porsche-911-technical-forum/452686-interior-refurb-carbon-fiber-71-a.html#post4433500 |
Headers of the correct size (1.5") will not make any more power on your mildly-tuned engine, but it will run a little cooler due to better airflow around and under the cylinders.
I would not use header wrap on anything due to severe corrosion issues, but I've had excellent results using a thermal barrier coating on the headers we buy, use, and recommend.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
What headers do you offer for this engine? What is this thermal barrier coating..
71 Targa 2.4 WEBERS 915 box Drivetrain - http://forums.pelicanparts.com/showthread.php?t=410787 Interior - http://forums.pelicanparts.com/showthread.php?p=4433500#post4433500 |
Anyone Use these? How would they rate?
from what I hear those are to big cars under 3.0
"Work harder........... Millions on welfare depend on you" " If you aint cheaten you aint tryin" |
What do you mean by "to big" ?
from what I hear the pipe size is to big for the cars under 3.0, there was just a thread about all this let me find it.
After reading some stuff they may work just fine, I saw that some manufactures said 1 3/4" is the biggest for cars under 3.0 some said 1 5/8", 1 1/2". Those obx have 1 11/16" primary tube lenghts witch falls right at the 1 5/8"- 1 3/4". Im gonna buyem.
HEaders
1 11/16 is just a "line" above the 1 5/8 and a line below the 1 3/4 Do you know if they will enhance performance in any way as opposed to the stock system?
I read somewhere that header wrap promotes corrosion, and plus the SS looks to nice to cover up. As for the gains I have know Idea but I’m guessing that if you go from heat exchangers to headers it’s a gain right there. The only reasons I’m going to go with OBX 1.) Price and material, 2.) The style cause I want to do a dual straight piped exhaust.
Anyone else chime in on Performance gains ....
Large Registered Member
'85 Carrera Coupe, Marble Grey #118 JP/R6 '93 Lexus SC400, '00 Ford F-150 '70 911T- 2.7 (SOLD) |
Hi PatrickB
I am considering a full exhuast for my 3.2. Can I get some details on your setup? Did you have to change any oil lines? Thanks
84 911 Targa 07 VW GTI |
OBX Headers
IMHO don't jump yet. Do a little more research. Exhaust larger than 1 1/2 dia on a 2.4 may cost you power rather than increase power. There is a definite relationship between displacement (cubic inches) and exhaust size. I'm running 1 1/2" headers on my 2.7 and I'm building a 3.0 but I'm staying with the 1 1/2 headers, I'll just be on the line between 1 1/2 and 1 5/8.
Kent Olsen 72 911 SCT upgraded 3.0L McMinnville, Ore |
Patrick,
Did you have custom pipes bent from the headers or did you find some off the shelf header to "street" adapters back to muffler segment. Obviously you went aftermarket on muffler and rear piping. In my appplication I was hoping to connnect a set to my M&K muffler with off the shelf adapters. OBX doesn't seem to know if their header works with the off the shelf "street adapters" for other headers to connect to an OEM style muffler. Anyone know this? Thanks
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
Rather than spend $650 or more for a muffler that would fit with a Porsche OEM manifold or get "stuck" having to purchase a matched muffler to header set ala B&B or GHL, I purchased a muffler for a third the price that has 2-3 times better flow. Any half way decent muffler shop can fab some extensions to connect the header to the muffler. The key is getting a strong support bracket welded to the muffler. Good strong support for the muffler lessens the chance for vibration transferred to the headers. Muffler shop will charge between $100-200 to do this work.
