Retired Member
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine. |
I noticed the machete on the wall ,too. But EVERYONE knows what that's for..... to protect vandals from getting their hands on your 11 blade fan, of course. Good luck on the engine. Be sure to have a machine shop do your heads and case, not worth the hassle and I figure if you don't have an engine stand you most likely don't have anything to grind valves. If you can affored it go with a new set of Mahles. Also, be sure to check the squirters in your cam towers to see that thay are open and clean. I assume you'll be using all your "on top" stuff from your other engine?
Re: Engine stand.... You can get regular a engine stand for about $49 and in Excellence Magazine there's an ad in the back for a 911 yoke "ring" that fits into a standard engine stand whole pattern.... it's only $130. or less. Moving your engine around: Get a small square floor dolly 22$ at HomeDepot, (4wheels) 20" x 20", then have some friends help you muscle the engine onto it. Now you can run a jumbo floor jack under the dolly and raise it to the engine stand height. After you finish the engine you can lower it again onto the dolly with the floor jack.....so your can now lift it up under your car ( ready on jack stands about 30" off the ground ) and up into your engine compartment. I recommend you drop you existing engine always with the transmissionn attached. With trans attached you will need to slide everything so center of gravy is nearer to the engine/ trans split line.... you'll see what I mean. Also, The mistake most people make is trying to install an engine while the car is only raise at the back. THE CAR MUST BE LEVEL SO THE ENGINE GOES STRAIGHT UP SO THE 4 MOUNTS MEET EVENLY. 2 at the engine cross member and 2 at the transmission. Don't forget to r/r the earth strap at the trans end. Glad to help if you have any questions. I was were you are now and you only get better as you do more and more. I used to think how nice it would be to have a place you can work on engine while others worked on theirs. Kind of like I got better playing guitar hanging playing along with people better than me. regards, RS |
Had no idea you were this far along.... good for you. Maybe my advice will help for next time. RS
Hi RelaySwitcher,
You must have started reading this thread from the "end". The rebuild is done. The engine is off of the engine stand and he is getting ready to reinstall the engine.... But I am sure someone else will profit from your suggestions!
*2005 Markleeville "Death Ride" 5 Pass Finisher. 129 miles & 15,000 ft. of climbing *California Triple Crown Member (3 Double Centuries in 1 Year) *2003 Giant Carbon Fiber Road bike with Topolino Wheels + a lot of goodies *2000 Torelli road bike - Campagnolo Chorus equiped + a few goodies *1999 Litespeed titanium, full-suspension mountain bike Shimano XT equiped + a lot of goodies. Bill Carcot 1979 911SC - Sold (Searching for a Boxster) 2000 BMW Z3 |
19 years and 17k posts...
Excellent write-up. Great work!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
The CIS is coming off of the 82 and being put on the rebuilt 80.
82 911SC Coupe Chiffon / Chocolate 9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD) |
Ordering clutch and tranny seals tomorrow. CVs will be cleaned and repacked. Not sure about the guide tube and the cross shaft ... I need Kevin's help with those items since this is all new to me. Hard to determine when something is worn when you have never seen a new one before.
15 hours in the garage today. Focus was on cleaning up CIS and tearing down the items on top of the old engine for use on the new one.
Here is a pic of the finished CIS minus the fuel injectors. I pulled all of them and decided to go ahead and order some new injector sleeves. The seals were super brittle. ![]() Can someone please help me identify these to connections indicated by the ? on the blue tape? I am holding the WUR connection to provide a point of reference. Both of those connections were strays - found them after pulling CIS.
I think the one on the bottom goes to the heater blower motor which you are hopefully doing away with. The other goes to a black round thingy that has a vacuume hose on each side, I forget what it does (decel valve). I dont see it on the top picture I think it attaches to the manifold some where...sorry not much help.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
thanks mca... I will check my inbox for pm or you can email me direct at bobf@design-associates.us
By the way, I thought I remembered something similar to my resto to yours... I am working on an 82 targa tub of which I have the matching # hole in the side case, cis, etc and a donor 80 long block of which I am trying to figure out where what goes where Thanks for the offer to send pictures... I cant wait as this will save my bacon and tons of time on the already 7+ yrs resto... Bob
I live for 911 tweaks... |
The other one is still a mystery. The decel valve doesn't have any current and has a vacuum hose that runs to a nipple on the cruise control servo.
Somatic Negative Optimist
mca:
Yes on the plug for fan blower; I think the other one is for something called Thermo Time Switch which you may not have; no problem. Check/replace the 2 plastic bushings in the shaft that actuates the throttle linkage. (The item on the left in your picture) After installing the new injector sleeves, some Vaseline on the new O-rings makes it easier to get the injectors in. You absolutely need to clean and paint the shroud! You'll love it! ![]() Attached picture with painted shroud plus Fan Blower, A/C, and Cruise delete. ![]()
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Gorgeous. Looks fantastic! I cleaned my shroud last night. Honestly it looks super so I don't plan on painting it. The only rough area is where the plug wires come across the fan shroud to 4,5, and 6. The wires will cover it up though. My thermo time has a connection. Got that one marked. Regarding the injectors ... Bentley says to soak o-rings in fuel for a few mins before installing. Is that correct? Also, I am assuming that I can put the injectors in after intalling the CIS onto the engine (obviously before putting the engine in the car). I don't see where it would be a problem but I just wanted to see if that was okay to do or if it would be difficult trying to work around the fuel lines. Thanks, Craig
I bet that plug does not go on that year. I know my 78 motor had that plug and it went to a doo hicky on the drivers side of the engine on top of the intake pipes. I believe I had to rig up a way to support it when I took the heater blower stuff out because the mount for it was on the side of the heater blower assembly. I want to say thermotime switch was correct but if you already have that plugged up... I dont know.
The mystery wire was fully wrapped in electrical tape so it wasn't as if it broke free on accident. Another interesting tid bit is that the 82 has a 35 degree celsius switch which is screwed into the breather cover (only on 81-83). Had to pull cover from the 82 engine and put it on the rebuilt 80 engine since I am using the CIS and harness from the 82. I seem to be missing the "additional 15 degree throttle position switch" which is also on the 81-83 models. Both of these are covered on page 240-28 of the Bentley.
The mystery connection in your photo connects to the cruise control vacuum servo located far forward on the driver's side of your engine compartment. It is visible from your photos of your empty engine compartment.
Fritz 1983 911SC |
I knew it had a vacuum line involved! :-)
That may explain why my cruise control never worked. Wonder why someone would pull it and wrap it with electrical tape. Maybe someone forgot to reconnect it after working on the harness? I think that I will keep it unplugged but I will make the wire accessible for future tests. If the PO disconnected it for a good reason, I don't want to find out about it when I try to crank her up for the first time. Again, thanks a ton.
I thought that I would mention a strange dream last night.
While my brain was processing wiring data all night and making connections (ugh, rough night) it managed to formulate a dream worth remembering. The car was on stands and I cranked it up for the first time. She purred beautifully. I remember being completely blown away by the new found horse power ... yet the car never left the garage. Somehow I was feeling the engine kick me back in my seat without the tires on the ground. It sure was nice though. Hopefully this is foreshadowing if good things to come .
There are lots of reasons why your cruise control wouldn't work. If that plug wasn't connected, it definitely wouldn't. I'm a bit anal about getting every system on my 83 SC to work correctly, and I've spent lots of time on my cruise control. If you decide you want to get your system operating, let me know and I'll share what I've done with mine. There are a number of threads about these early cruise control systems available and that's where I did my research. My system works very well and I enjoy using it when driving on boring interstate when I want to avoid inadvertently staying at that 90+ MPH sweet spot.
Fritz 1983 911SC |
