72 four door's Avatar
sway bar question
Have access to a 19mm rear sway bar for my 72 what size should i go with on the front. It will only be used on the street.
82 911
70 GTO
97 GT Ragtop
74/76 Jeep cj's
Old 03-23-2008, 05:15 AM
ttweed's Avatar
I would use a 19mm adjustable bar in the front with it. That should give you a range of adjustment to balance the car's handling. Your other choices for a stock look are the 16mm and 18mm fixed OEM bars. All the larger OEM bars are "under the body" types, not the "thru the body" type used in '72.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 03-23-2008, 07:24 AM
