Problem with some gauges..
Hi everybody, i think i am having some problems with the oil gauges or maybe a general electrical problem.
The oil temp gauge reads aparently fine, but when i go at cruise speed across a not perfect portion of road it moves up, and then down, and if i depress the aceel pedal it goes down a little bit, and recover real temp when accelerating. The other problem is that the light in the top of this gauge set (the one that says OIL and the handbrake simbol) is always blinking. I have the handbrake down, also tryed to take out the cable of the sensor and make a little shortucut to check if the sensor was going bad and the light was still up and blinking. I checked the oil at the tank, and the level was ok. So i don't know why this light is blinking, also with this light i hear a noise like the one you hear when the turn light is on. The other problem is with the oil level gauge. It's always at zero, well, under zero. i removed the gauge and take otu a cable from the back and if i remove it the gauge marks full, 100%, so i think the problem is not the gauge itself, but i don't know where this cable cames from. |
Max Sluiter
What kind of 911 is this?
Check the ground wires, battery terminals, and fuses first.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Hi Welcome to Pelican. It would helpful to all if you include your location and your car year and model in your signature
Hi, i forgot about my car.. jaja its a '73 911T with MFI.
