There were two 914's made with 908 engines...one for Ferry ( with silencers and such. slightly detuned...the other for Piech closer to racing 908 HP tune, and a bit more raw.....
..but mid-engine...not an 8 hung out way past the back axle !!
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-30-2008, 07:29 PM
Az911's Avatar
Send a message via AIM to Az911
Originally Posted by EarlyPorsche View Post
What about when the Corvette SS comes out though? 600-650hp for $100,000 even. Thats Carrera GT/Enzo power.
100K is a lot to pay for a car that comes with leaf spring suspension and shares parts with a malibu. Your forgetting people buy a Porsche for more reasons then just HP.
72T RS look
96 993
Old 03-30-2008, 07:30 PM
sudo apt-get purge 930
equality72521's Avatar
WTH, forget a flat 8, maybe porsche should go with a V8. I heard a couple of american car companies have done well with it.
Hell, people are already swapping Chevy V8's into them. Great straight line cars but handle like a cow.
--clutch-monkey
Az911's Avatar
EarlyPorsche if you want a v8 so bad go buy a camaro/vette.
72T RS look
96 993
Old 03-30-2008, 07:32 PM
300hp 1800lbs is the goal
pksystems's Avatar
Originally Posted by ninesixfour View Post
Do these cars really need more power? I'd rather see the 998 lose 400 pounds than gain another 50hp.
Exactly.
Even the Carrera GT/Enzo are overweight pigs (McLaren F1 did something right with CF)
Alot of you guys are doing as much weight reduction as possible.... what do you think the heaviest item (other then frame) is in your car? It's time for smaller turbo motors
There is a reason Lotus Elise/Exige are very fast track cars, and it's not cause they have 600hp
All depends on what you want I guess....
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 03-30-2008, 08:42 PM
ToddM's Avatar
Send a message via AIM to ToddM Send a message via Yahoo to ToddM
Sorry, if Im going to pay $ for a car that has every gear PRESSED onto the mainshaft and that any sign of problem leads to replacing either the transmission or engine (hopefully under warranty), for $70K you can pick up a Nissan GTR (7:38 on the ring) which is faster than any of today's Porsche street offerings except the GT (same can be said for the Z06 for those menationing Corvette) which does in the ring in 7:36.
The Nissan GTR is a 3.8L 6cyl TT V6. This is apples to apples, if Porsche has their ***** together, they should be able to do the same with a flat 6 3.8L TT
-Todd
'82 911 SC Coupe w/'92 3.6L, bulletproofed 915/62 w/GT LSD & Wevo goodness, Rennsport RSR/Bilstein Sport, SRP ARB, ER Polybronze, BK strut brace, 15x7/8" Fuchs.
Sold: 92 964 Turbo, 81 SC, 96 993 Coupe, 82 SC, 89 Carrera Cabriolete
Old 03-30-2008, 09:06 PM
Skunk works
JV911SYDNEY's Avatar
GT is CF monocoque & panels. weighs approx 1300kg/3000lb...about the same as a Mazda 3 hatchback. Thats darn light in my book.
granted its almost 400lb heavier than the F1 (il capo di tutti capi) but there is a lot more safety equipment etc that has to be built in these days
964 RS-4
Old 03-30-2008, 09:13 PM
Hmmm, not sure where you got that quote from, I never wrote that.
To note: a V8 does not have the low slung weight of the flat 8. Keeping the cylinders and heads lower makes the handling work like it does.
Old 03-30-2008, 09:18 PM
Never mentioned wanting a V8. That would not be Porschesque. I am looking for the low slung weight of the flat engine with the grunt of the 8. I guess another consideration is that a bit more torque could really help out these cars for the day to day drive as well as on the track. Not needing to run around at 3,000-4,000 all day would add some longevity. I mean I can't be alone on this am I? If I am then I know that my flat-8 dream is just wrong. Although a side of me is hoping Porsche is reading this.
Old 03-30-2008, 09:21 PM
The GT2 went faster around the 'ring. I'd also be more willing to believe that GT2 that Rohrl drove is closer to what rolls off the showroom floor than the GTR that held the record for a couple months. Only time will tell.
'84 911, some sort of red color
'05 Subaru WRX wagon
Old 03-30-2008, 09:58 PM
Max Sluiter
Flieger's Avatar
I agree that today's cars are too heavy. The M3 is 3600 pounds! Who cares if it has 400 hp and a V8. It needs it to lug its massive bulk around. Same for almost all other "performance" cars, except for things like Lotus (Loti?). My car is stripped of all non-essentials and weighs 2000 pounds. It does just fine with a 2.7 liter flat 6 with 210 hp and 188 lb/ft of torque.
EarlyPorsche, I think you are alone in wanting a flat 8 in a 911.
I fail to see the reason behind your beef with turbochargers, furthermore.
I don't mean to be too harsh- don't take this post in the wrong way.
Old 03-30-2008, 10:05 PM
I wasn't quoting you. That was my comment.
--clutch-monkey
Old 03-31-2008, 05:41 AM
These days, all high performance cars deliver essentially equivalent quantifiable performance. Some appeal to cost accountants, others to quality engineers & drivers.
Old 03-31-2008, 06:45 AM
MBruns for President
JeremyD's Avatar
I think the last thing you would want is a longer engine with more rear weight basis =
Now - a flat eight cayman - 3" more wheelbase - Now you are talking.
Still though modern turbos - DI, variable vane - that's where it's going. And I too cringe at some of these "heavyweight" sports cars - the Nissan is 3900 lbs - the M3 is 3600 lbs. At least the Z06 is closer to 3000 - Keep the power - lose the weight - that's what I would do.
Old 03-31-2008, 06:59 AM
Porsche 911 SC, SAAB SPG
If you are looking for more low-end torque from the flat-six, you need to either upgrade to a bigger displacement six and/or up the compression ratio.
I'm sure others with more engine experience can chime in as which flat-six engine solution would provide maximum low-end torque. There is always a trade-off between high rpm horsepower and low-end torque. Perhaps the 3.6 Varioram engine would be your best option.
Old 03-31-2008, 07:10 AM
911 & 930's are a mind set, they are flat 6 and there is no substitute.
If you want something different go for it. I would NOT change the handling and performance of our "flat 6" cars. My2c.
Old 03-31-2008, 07:42 AM
Az911's Avatar
Good luck actually finding a GTR for 70K. Nissian isn't bring that many over and the ones that are comeing will have big premiums added to them. Plus at the end of the day it's still a nissan.
72T RS look
96 993
Old 03-31-2008, 08:12 AM
copbait73's Avatar
Agreed, we longhood guys have it made. Just install a 3.6L (250-300HP). If that isn't good enough, go for excess; gut and 'glass it down to 2000#.
Old 03-31-2008, 08:15 AM
That's the answer. How many decades ago was Porsche making 1500 hp cars? Everyone knows they can do it. That's not the issue.
On the flip side, I remember maybe 20 years ago reading the chart about cars in the back of Road & Track - the one that is a summary of all their tests of the various cars. There was one car that was faster than any car on the list, both 0-60 and through the slalom. It was the one that was bolded on those figures - and some others too. Then at the end of that car, where they had comments, it said "a bit pricey for a 4 cylinder." I was flabbergasted. Here the car was, best of the heap, yet they criticize it. Maybe they should have said "did with 4 what others couldn't do with 6, 8 or 12."
Old 03-31-2008, 08:40 AM
it seems everyone is busy justifying 6 cyl.
Just one question, tho, what great good are 8 cyl. going to bring? Why would you need 8 cyl?
Old 03-31-2008, 09:34 AM
