There were two 914's made with 908 engines...one for Ferry ( with silencers and such. slightly detuned...the other for Piech closer to racing 908 HP tune, and a bit more raw.....
..but mid-engine...not an 8 hung out way past the back axle !!
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
100K is a lot to pay for a car that comes with leaf spring suspension and shares parts with a malibu. Your forgetting people buy a Porsche for more reasons then just HP.
72T RS look 96 993 |
sudo apt-get purge 930
Hell, people are already swapping Chevy V8's into them. Great straight line cars but handle like a cow.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
EarlyPorsche if you want a v8 so bad go buy a camaro/vette.
300hp 1800lbs is the goal
Even the Carrera GT/Enzo are overweight pigs (McLaren F1 did something right with CF) Alot of you guys are doing as much weight reduction as possible.... what do you think the heaviest item (other then frame) is in your car? It's time for smaller turbo motors ![]() There is a reason Lotus Elise/Exige are very fast track cars, and it's not cause they have 600hp All depends on what you want I guess....
The '66 912 Bastardization project has begun. Note to PO's: LAY OFF THE FREAKING BONDO!!!! The science was settled: Earth was flat. Galileo : Flat Earth denier.
Sorry, if Im going to pay $ for a car that has every gear PRESSED onto the mainshaft and that any sign of problem leads to replacing either the transmission or engine (hopefully under warranty), for $70K you can pick up a Nissan GTR (7:38 on the ring) which is faster than any of today's Porsche street offerings except the GT (same can be said for the Z06 for those menationing Corvette) which does in the ring in 7:36.
The Nissan GTR is a 3.8L 6cyl TT V6. This is apples to apples, if Porsche has their ***** together, they should be able to do the same with a flat 6 3.8L TT
-Todd '82 911 SC Coupe w/'92 3.6L, bulletproofed 915/62 w/GT LSD & Wevo goodness, Rennsport RSR/Bilstein Sport, SRP ARB, ER Polybronze, BK strut brace, 15x7/8" Fuchs. Sold: 92 964 Turbo, 81 SC, 96 993 Coupe, 82 SC, 89 Carrera Cabriolete |
Skunk works
granted its almost 400lb heavier than the F1 (il capo di tutti capi) but there is a lot more safety equipment etc that has to be built in these days
964 RS-4 |
To note: a V8 does not have the low slung weight of the flat 8. Keeping the cylinders and heads lower makes the handling work like it does. |
Never mentioned wanting a V8. That would not be Porschesque. I am looking for the low slung weight of the flat engine with the grunt of the 8. I guess another consideration is that a bit more torque could really help out these cars for the day to day drive as well as on the track. Not needing to run around at 3,000-4,000 all day would add some longevity. I mean I can't be alone on this am I? If I am then I know that my flat-8 dream is just wrong. Although a side of me is hoping Porsche is reading this.
'84 911, some sort of red color '05 Subaru WRX wagon |
Max Sluiter
I agree that today's cars are too heavy. The M3 is 3600 pounds!
Who cares if it has 400 hp and a V8. It needs it to lug its massive bulk around. Same for almost all other "performance" cars, except for things like Lotus (Loti?). My car is stripped of all non-essentials and weighs 2000 pounds. It does just fine with a 2.7 liter flat 6 with 210 hp and 188 lb/ft of torque.EarlyPorsche, I think you are alone in wanting a flat 8 in a 911. I fail to see the reason behind your beef with turbochargers, furthermore. I don't mean to be too harsh- don't take this post in the wrong way.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
These days, all high performance cars deliver essentially equivalent quantifiable performance. Some appeal to cost accountants, others to quality engineers & drivers.
MBruns for President
I think the last thing you would want is a longer engine with more rear weight basis =
Now - a flat eight cayman - 3" more wheelbase - Now you are talking. Still though modern turbos - DI, variable vane - that's where it's going. And I too cringe at some of these "heavyweight" sports cars - the Nissan is 3900 lbs - the M3 is 3600 lbs. At least the Z06 is closer to 3000 - Keep the power - lose the weight - that's what I would do.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Porsche 911 SC, SAAB SPG
I'm sure others with more engine experience can chime in as which flat-six engine solution would provide maximum low-end torque. There is always a trade-off between high rpm horsepower and low-end torque. Perhaps the 3.6 Varioram engine would be your best option. |
911 & 930's are a mind set, they are flat 6 and there is no substitute.
If you want something different go for it. I would NOT change the handling and performance of our "flat 6" cars. My2c. |
On the flip side, I remember maybe 20 years ago reading the chart about cars in the back of Road & Track - the one that is a summary of all their tests of the various cars. There was one car that was faster than any car on the list, both 0-60 and through the slalom. It was the one that was bolded on those figures - and some others too. Then at the end of that car, where they had comments, it said "a bit pricey for a 4 cylinder." I was flabbergasted. Here the car was, best of the heap, yet they criticize it. Maybe they should have said "did with 4 what others couldn't do with 6, 8 or 12." |
it seems everyone is busy justifying 6 cyl.
Just one question, tho, what great good are 8 cyl. going to bring? Why would you need 8 cyl? |
