Throw it on the ground!
Is there a min ambient temp for A/C charging?
Was planning on doing the A/C charge this weekend. Just checked the forcast and we've got another cold front moving in with projected weekend highs in the mid 60's
The 134a PT charts start at 70 - 80 degrees. Rule of thumb says shoot for high side readings at 2.2 times the ambient temp. OK to proceed, or should I just wait for hotter temps to charge?
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
el bump-o!
I am not an expert but here is what I learned. The biggest reason you want a warm day is to get a better vacuum on the system. We all know that water boils at 212 degrees at sea level. If you drop the pressure, water will boil off at normal ambient temperature. You will get more moisture out of the system because more water will boil on a 99 degree day than a 60 degree day at maximum vacuum. The one truism is you will never have to much vacuum before you charge your system. Even though the vacuum pressure will read the same, a 100 degree day will get more moisture out of the system than a 60 degree day.
How much moisture do you need to remove is like asking how much wealth is enough. There is no such thing as too much.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! Last edited by GH85Carrera; 04-08-2008 at 06:48 PM.. Reason: stupid typos |
I just had to charge the system on my Jeep. I am no expert but this is what I found out...
Ambient temp at least 70 so your refrigerant bottle can provide enough gas. You don't want to add it as a liquid unless you are vac'ing out the system and adding by weight. I assume you have the gauges and refrigerant. What I did, and this was at the advice of a 30-year refrigeration tech I work with, was hooked up only the low pressures side. With engine off the low side gauge should be at about 70 psi. Start the engine and watch the gauge - when the compressor is running the gauge should read about 35 psi, if not add 134a as a gas while engine is running. Every time the compressor shuts off, the gauge will creep back up to around 70psi and drop back down to 35 when the compressor kicks back in. This worked like a charm for me. Hopefully it doesn't all leak out before my vacation next month.
Brendon 80 911SC "Weissach" 77 930 (in pieces) |
I'm not sure about re-charge but when evacuating the system, the warmer the better to get max moisture out of the system. I'd wait. Ken
I never charge any A/C system without a complete gauge set. The high side pressures are critical and need to be observed. Decent gauge sets are inexpensive enough so you can have a dedicated set for R12/22 and a set for 134A. Maybe it is just me, but I like seeing the pressures on both the high and low side.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
I'll wait. It's killing me, but I'll wait ![]() PS - yes I do have a shiney new vacuum pump and guage set just begging to be used! Thanks for the replies!
Didn't mean to imply that I was focused on high side pressures only with my comment - was just imputing high side pressures below the chart ranges using "rule of thumb" at 2.2 times ambient temps. Don't know where low side and evap temps should be at charging ambients below 70 degrees. Perhaps that's why they're not published b/c evac charging conditions are not favorable for good DIY results. Due to conversion to 134a and substantial system mods (2 condensers added) my actual refrigerant capacity is now "unknown" ,therefore, the charge must be optimized using the Pressure and Temperature charging method. I've learned alot here guys! (I think )
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 04-09-2008 at 05:41 PM.. |
I haven't seen anyone talk about the most important part of charging a system.... that is how much PAG oil are you going to inject into this system?
Without any or very little you will burn up the compressor very quickly. That also helps with any moisture that might be left in the system Not knowing how muck R134a to put in is a problem without a good set of gauges or an A/C machine. At 75 degrees your gauges should read 28-34 low and 190-240 high. If the temp is lower both set of numbers will read lower. And don't forget to have the fan going on the condenser, if that isn't running that will make the high side rise quite a bit.
Denny 1976 911s targa 1974 widebody G2 style GroupeB 76 www.G2Performanceshop.com Cylinder head recon, case savers,twin plug,rocker arms |
Livin' the Dream
This is a good article that says ambient temps should be above 84 degrees. This article is not 911 specific, but is very informative. I need to rebuild my compressor, so haven't followed his technique yet, but I will definitely give it a shot.
http://www.aircondition.com/wwwboard/alternative/current/7842.html
'84 911 Carrera |
As an HVAC/R tech the warmer the better for the vacuum but charg byweight to spec.will keep from cooking the compressor in the long run. mfg .weight should be listed in the manual or on label in compartment .
Marty H. 77 targa 2.7 some shade of red 09 pilot kid hauler 11 Nissan juke 12 transit connect daily |
I've read numerous recommendations not to create an artificial environment such as using box fans to cool the condenser. Rather, close the deck lid and go slow and BE SAFE. None of us are getting out of here alive, but this is not how I want to go! My 2 cents and thanks for the input.
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 04-10-2008 at 11:33 AM.. |
