Head Stud Replacement without pulling heads?
I know this is a dumb question, but from looking at pictures and diagrams is there a reason that a single head stud could not be backed out and pulled through the head without pulling the head assembly? I am guessing that either there is no way to get a grip on the minimal amount of the stud the sticks through the cam housing or that heat is required at the point where the stud threads into the case. I have two broken head studs I need to replace - one on cylinder 1 and one on cylinder 3 on an 87 Carrera. We will probably replace the clutch soon so we will have the engine out of the car. I was kind of hoping I did not need to take the heads off.
Wishful thinking I'm sure.
Bill |
I don't see how.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
GAFB
Not gonna happen. Besides, you'll really want to be replacing all the lower 12.
Several BMWs |
I *think* people have done it before. At least I'm pretty sure I remember reading some posts here (including pictures) of guys that have done it. From what I recall, it was a lot of work, though. Try doing a search and hopefully you can find the post(s).
Friend of Warren
"the" is correct. The was a thread some years back of an ingenious guy who managed to work out a stud without removing the head. Of course he spent about as much time doing it as it would have takend to drop the engine and remove the head.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Hmm - kind of like the guys in school that work so hard to cheat, it would have been easier just to study.
The car just had a compression test and leak down that came out as close to perfect as you can get (165 and 0% on all cylinders) so I am not in any hurry to do this - but it does concern me.
Bill |
Slumlord
Can one of you guys point me to the thread of the guy who managed to pull the studs without pulling the heads? I can't seem to find it with the search function.
Bill |
82 SC , 72 914 |
basically he got at the exposed bit of stud between the bottom of the cylinder and the case and over about a 6 hour time period, managed to turn it out in 1° increments with mini visegrips or something like that. lucky his stud was moveable, unlike most of them that need lots of heat to melt the loctite. more patience than i have.
My grandfather used to tell me "A lazy man will kill himself at work."
GAFB
Several BMWs |
Autobahn Garage
If you can't find the time and money to do the job correctly the first time, How will you find the time and money for the second time?????? Just a question that runs though my mind
T Tanner 76, 911s w/ Webers 76, 914/4 57, Speedster |
We'll do it right the first time - just curious if it could be done this way or not. The 4 different mechanics I have spoken to all say it is fine to drive it as is until we start to hear some exhaust leakage or get a cylinder leak. I'll probably address it before then - as I said I need to replace the clutch soon anyway. I have R&R'd my 930 engine and tranny a few times and replaced the clutch, but I am not comfortable with cam timing so I will likely just give the engine to my mechanic to work on or maybe have Tom Amon come by our house for that part of it. Thanks for the input.
Bill |
Slumlord
Save some money. Buy Wayne's book and do it yourself. If you work through it methodically it is not hard.
And there would be lots of guys here to help. |
