Air Medal or two
afterburn 549's Avatar
Alum cross member /sway bar ?? HELP
Installing a Aluminum cross member (front) , the old steel one used tabs for part of sway bar mount.
Which or what sway bar now ?? HELP
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 04-21-2008, 05:15 PM
grateful user
don gilbert's Avatar
just did the same thing to my 75s. u use the same s/bar . what i did at first was cut off the old mounts on the steel x member and modify them (drilled holes and put a s/bend in them) but then i bought an 82 sc parts car and got the original mounts. it works the same way, its just that the steel x/member has the mounts welded on and the aluminum ones are bolted on. if you want e/mail me and i will ship you my modified ones.
Old 04-21-2008, 06:44 PM
Air Medal or two
Hmm yea and yes and , no,,? I am thinking now maybe might be a good time to up grade. Now that I have 20 /20 hind sight........ LOL
One of the through body designs might be the right thing to do ??
Old 04-21-2008, 06:48 PM
cfc cfc is offline
sway bar
I must be loosing it. If you are installing a front aluminum cross member that must mean you have a 1964 to 1973 car, since they had steel cross members. The sway bar on those cars did not touch the cross member? What am I missing?
Old 04-21-2008, 07:49 PM
Air Medal or two
No it is a 75, But it had a steel one there and I just want the lighter fare........
Old 04-21-2008, 07:58 PM
