Cigars and 911's -- Smile
Thanks for the great detailed thread.
Wondering best vendor to source POR-20 aluminum satin paint . . . .
[GruppeB # 978] 1978 911 SC ROW (Pure Euro, no DOT or EPA work done..) 1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket) 2001 Audi - A6 Quattro 4.2L-V8 (love the growl) 2014 Honda Odyssey for the soccer-team/accessories |
Member 911 Anonymous
Please keep us posted on the 5 Watt LEDs when running during the day with lights off. I hope you are succesfull ![]() Funny thing is that I have installed a LED third Brake Light and it does not glow. Apparently the DOT combo absorbs the leak and does not effect the Third Light LED. BTW, I pasted aluminum foil where the reflective material has flaked off in the brake light and it worked great.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 04-23-2008 at 06:34 PM.. |
Hey POP,
Any updates on the LED, specifically the low glow of the LEDs when the lights are off with car on?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Just noticed, shouldn't the amber turn signal bulb above be an 1156, not two filament 1157?
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
Carrera Cab Connoisseur
subd
Dave 1986 Carrera Wide Body Cabriolet 1993 Nissan 300ZX Twin Turbo (620rwhp) 2003 BMW 330Ci MSport Individual 1973 Mercedes 350 Custom Convertible |
Inspired by Jeff"s thread here, I got two of Super Brights 5 watt LED bulbs for my 74's taillights. I'm happy to report that, in addition to their many other advantages, they are (I'd estimate) about 20% brighter than the traditional two filament bulbs and, just as important, the directional coverage seems excellent. This is indeed an improvement in visibility. On the Super Bright site, the bulbs are the 1157 RLX-5's. The R means red, which is essential if you want to get the expected brightness.
Now did you confirm if the rear lights remained off when you turned the lights off and car on? My LEDs glowed when she was on and lights off. Please advise,
Awesome write up POP!! Be sure to post some pics on car.
Anyone replace 3rd brake light (high mounted inside rear window, on '86) with LED? What LED cluster would work best here? thanks
Mike '86 911 coupe '85 BMW 535i '11 Cayenne |
I have no lights on with switch off.
There is a Pelican thread on doing an LED third brake light. BUt everyone (except me I guess) has missed the easy and sensible solution...the Hella aftermarket LED third brake unit available from daniel stern lighting. $50, very bright, looks like it belongs on the car, in contrast to some of the kluged together set ups on the thread. Take a look.
Monkey Butt Forespin
$.02 from a guy who did the superbrightleds.com bulbs for his Taurus SHO years ago, including the resitors to compensate so you don't get the lamp out lights on the newer cars...
The lights (when I got them, about 2 years ago) looked great on the bench. However, in the light / twilight out on the road, I had many people tell me they couldn't see my brake lights. I tried the white bulbs behind the red, then the red bulbs behind the red... no real change. Thought I'd share. Incidentally, yours do look great, hope they work out for you, but watch the rear-view, just in case...
Fred Hurder Jr For Tech Questions: '84 911 Carrera Cabriolet (US) Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler 22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
Thanks, I'll keep my eyes open. My impression is that the LED units are improving all the time. In particular, many of the newer units are visible in a 200° arc, not typical just a couple of years ago when there were many complaints that if you got off axis the lights were invisible. Unless these new bulbs deteriorate rapidly or something else untoward happens, they are looking very good. They are brighter than stock and they show very good visibility well to the side of the car (ie off axis.)
[QUOTE=moneymanager;3977726]I have no lights on with switch off.
QUOTE] Great, looks like I am pulling the trigger on those 3-5 watt babys
Subbing
MBruns for President
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Subscribed! Great thread. Will tackle this in the future!
Mike |
Well Gentlemen,
It is an Afirmative! The RED 5 Watt Luxeon LED Brake Lights (1157-RLX5) worked. Much brighter than OEM or the other LEDs and the angle of view is perfect. Apparently the 5 Watt LED draw a bit more current which absorbs any bleeding of OEM current. When the ignition is turned to the on position, no glow to report. Thanks again POP and MoneyManager for confirming that lights don't bleed. Again, Wow So Bright! It kind of burned my eyes.
Glad they worked out Draco...your experience is exactly like mine. These LEDs, plus my socket repairs and some other refinements have given me the best rear lighting I've had in years!
Here are some pics from my cell:
![]() Brakes OFF ![]() Brakes ON ![]() Unlike the standard LEDs, it completely fills the brake light housing with light. ( see post 34, sorry JeremyD ) BTW, the Luxeons are brighter than the third LED light as well.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 06-10-2008 at 05:05 PM.. |
Strange, I wonder why your first pic has that distinct LED outline??? Are you using the Luxeon 5 Watt as well?
